Question about Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer
Canon mp250 error no paper
Pulls paper about an inch and gives no paper error but there is paper in it.
    New Friend:
    Problem Solver:
  • 7 Answers
Get a q-tip and wipe roller with rubbing alcohol on the q-tip. This should renew the friction ability of the rollers.
Posted on Jan 14, 2013
mybox258
  • 74 Answers
SOURCE: E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Posted on Dec 24, 2008
  • 42 Answers
SOURCE: Persistent paper jam error
How old is your model? This could be dirty rollers. See how I fixed that problem on this site: http://annoyances-resolved.blogspot.com/2009/09/paper-jam-buy-new-laser-printer.html
Let me know if this helped. OK?
Posted on Oct 01, 2009
  • 117 Answers
SOURCE: I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Posted on Oct 09, 2009
SOURCE: canon mp250 paper will not feed snags on something
I had a paper feed problem with a Canon MP 250 and solved it this way. (not my own)
After many attempts t clean the feed rollers etc. I tried the following.
I cut a piece of card stock about two inches wide. I fed this sock from the front to rear and carefully worked the card stock in and out and from side to side (flossed it) and dislodged a drywall screw !!
I realize that having a drywall screw lodged in the paper feed is not common, however this "flossing trick may help to clear the paper feed path in other situations.
Posted on Dec 05, 2010
  • 11 Answers
SOURCE: canon mp250 E03 code but
Take all of the paper out and turn it off then back on again. If this does not work take all of the ink out of it and do the same thing.
Posted on Feb 05, 2011
Paper jam
Have you tryed replacing replacing the pick up rollers? Also make sure that the paper guides are snug against the paper.
Jul 06, 2013 | Brother MFC-7820N Printer
Paper Jam error
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure thatyou have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
May 17, 2008 | Olympus P-440 Thermal Photo Printer
Paper jam display
Most printers have a lid in the back of the printer that you can pull out and then just pull the paper out from there. You can also see the paper jam if you pull the paper tray out and try to pull it out from there but pulling from the back of the printer is much more easier and convenient.
Hope this helps. If have the model and printer information I might be able to give you more information. Sometimes even a tiny bit of paper will give paper jam error so it is necessary to clear it completely.
Mar 09, 2013 | Lexmark X5470 All-In-One InkJet Printer
Printing doesnt start at top of page
Sure the paper is correctly document may be the printer thinks the paper is metric instead of inch check the printer setting
Jul 12, 2012 | Minolta magicolor 2400W Laser Printer
We have an Oki 5200c and are printing color postcards on 110 lb card stock. The properties for the printer are set to heavy paper. We have tried using the regular drawer and almost immediately it stops...
Wrong size paper or paper setting in the software settings. Or the dreaded plastic gear/roller cam has warn down. You'll notice some parts are plastic designed to ware out.
Apr 17, 2017 | OKI C5200n Laser Printer
Hello, Our machine clicks when attempting to pull
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play. If the rear guide is tight, that is the problem. You can check for this by depressing the lever on the right front of the tray. Depressing the lever should raise the stack of paper out of the tray so that it can slide forward.
If you remove the paper from the tray, but will see calibration marks for the paper size you are using. Unlock the read paper guide n the tray, squeeze the release and move the guide ot the mark for the size paper you are using. For example, it you are using letter size paper, the read guide should point to "LTR".
Aug 17, 2010 | Brother MFC-8860DN All-In-One Laser...
Paper Jamming
The problem with your printer is likely to be dust getting the way of your sensors; preventing it from seeing paper, preventing the rollers from effectively feeding the paper. This is if you are sure all other things are in proper working condition. Just get a long reach brush and try to reach in as far as possible and brush as best as you could, front and back is there is access.
Sep 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
May 30, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Jan 03, 2009 | Office Equipment & Supplies
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
old marine
old marine
