Question about Air Conditioning and Heat for Ford E350
Front floor heat
Air will not switch to hot
  • Ford Master
  • 14,363 Answers
Blend door is stuck,cable may be bent.
Posted on Jan 04, 2013
Floor heat
Your actuator is bad on the vent door, that switches from cool to hot. some units have several of these, some only have one
Jan 12, 2015 | 2003 Toyota ECHO
1996 Montero Heater Blower not working
I assume your heater setting is electric control, if so either your defrost and floor heat switch failed or wire problem. For the air not hot, check the heat control valve on the top of the hose it should be in front of the firewall. I don't know your car is using mechanic valve or electric control valve. Anyway check there first. Good luck.
Nov 24, 2013 | 1996 Mitsubishi Montero
Rear Floor Vent heat only
Sounds like your heater coolant hose door flap is broken or loose. May want to check behind the heater controls, if your components are mechanically operated. If electronically, may need to perform more troubleshooting before replacing this component.
Jun 17, 2017 | 2004 Ford Econoline
Hot air through floor in 99 Suburban when blower is switched off
I the short answer is yes. The truck has a flow-thru vent feature as does most GM products. When the fan switch is off the outside air would flow into the truck.
I thought you could still direct the air by way of the control panel, but by the wiring diagram it looks like everything is disabled when the fan switch is in the off position.
Aug 24, 2012 | Chevrolet Cars & Trucks
No hot air heat to floor on 2000 ford contour
you could have a bad switch, the vacuum lines could be leaking, or your blend door could be bad
Dec 01, 2011 | 2000 Ford Contour
99 4Runner heat blowing from console behind driver's seat
It sounds silly but there is a separate unit in your console that you can only turn off if you go in from back seats. You probably already did that, but if not try. You can not turn it off from any controls on front panel. If it doesn't work, I would think something is wrong with the switch. Open it up and look at wire connection from switch regulator. It also has a heat regulator on the console facing back seats? Mine does anyways.
Jan 17, 2009 | 1999 Toyota 4Runner
No dashboard heat output
The climate control was poorly designed on these cars.
There is only heat on the floor and defrost settings, due to the layout of the ductwork.
Oct 22, 2008 | 1989 Ford Festiva
Air Conditioning and Heat for Ford E350 Logo
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
