Question about Microsoft Xbox 360 Slim Black Console
My Xbox360 has started to get very hot, plugged in, but not even on??!! I recently had to use the TV it is hooked up to very shortly as a monitor for my computer. While I was using the computer, I noticed the Xbox was very hot to the touch, but it wasn't even running? What gives? If I turn it on, everything works, but it heats up very quickly, am afraid to use it, any ideas? Now I am only using the TV for the Xbox again, but this is still happening, I have to unplug the xbox, or it just heats up sitting there!! NOT ON!
    Problem Solver:
  • 10 Answers
OK you gotta clean the vents. The xbox needs airflow and lots of it. :)
Posted on Jan 03, 2013
JMuskovitz
  • 135 Answers
SOURCE: My Xbox won't turn on
Do you have the replacement power cord (from the power cord recall)? If so, this has a built-in circuit breaker, and a button to reset it.
Posted on Mar 25, 2007
  • 7 Answers
SOURCE: Please insert this disc into a xbox 360 console white screen
I just had a similar problem, sent it away in it's coffin yesterday :(
Posted on Oct 01, 2007
  • 68 Answers
SOURCE: Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Posted on Apr 03, 2009
SOURCE: green/red pixels on tv while xbox360 is on
its your junkbox getting ready to redring. Thanks Bill. unfortunately ive had the pleasure of watching 3 do this. One today. .
Posted on Sep 12, 2009
SOURCE: 2 ring of death
MS is one of the worst companies I have ever seen in reliability. If something of theres doesn't work they say woops! Buy a new one.. and they move on to steal more ideas.
I got the 2 ring of death and tried the xclamp fix- worked for 30 min. Doesn't run more than 5 mins now. There is no dust in it and the fans are working fine.
I've read that my xbox my have gotten so hot with the default config that it melted the sodder off itself. WTF
If someone finds a GOOD solution (versus the typical MS resonse given by localwonder)
Also I have run my xbox with a fan blasting air into it and this doesn't affect the 5 min uptime.
Posted on Sep 30, 2009
I can't connect my xbox360 to my sony pfm-42b2 tv
Keep in mind that your Sony IS NOT A TV, but a monitor instead. There is an actual XBOX360 VGA adapter that's available at most gaming retailers. It was initially designed for those who wanted to use their PC monitors for there console gaming. HDMI is NOT compatible with a VGA input as HDMI is a digital signal type and VGA is an analog type connection. You must also remember to have the XBOX set to a NON-progressive resolution (480i) if trying to hook it up using the standard XBOX video cables.
Apr 17, 2012 | Sony Televison & Video
I just hooked up my Xbox with and HDMI cable, however my samsung tv does not read it, and I cannot select the HDMI function in source
Ok, I don't have an XBox360 so I can't get specific but if you can't select hdmi input on the TV then you are probably not getting a HDMI signal. I would check your XBox360 set up to be sure that it is set to output video on HDMI not composit, s-video, or component. You might have to return to the last working setup and monitor so that you can see the menu to make the change.
Hope that helps,
Gil
Sep 21, 2011 | Samsung LN40D550 LCD TV
2000 silverado starter continues to try and start once the power is hooked up to the system. I recently replaced the starter and the starter relay. Also, once I hook up the negative terminal, it gets very...
You need to recheck your wires that you hooked up when you replaced the starter.You possibly have some that could be touching each other.If the the positive cable touches the purple wire on the solenoid the engine will turn over when you hook up the battery.Check your wiring very carefully.Hope this helps.Good luck.
Sep 08, 2010 | Chevrolet Silverado Cars & Trucks
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Xbox360 shorting out TV
could be its not plugged in correctly
Oct 27, 2009 | Microsoft Xbox 360 Console
I have a Dell 19" flat screen TV/Monitor that came with the computer and is my computer screen. While watching, the picture went black. We have determined that it is the TV/Monitor by hooking up another...
Try these :
1.) reinstall your operating sys .
2.) sounds like there is a short somwhere. is it under warranty?
3.) Check the plug-in for the external power pack. Mine did the same thing and it turned out to be an old and week connection at the plug... the contacts were not fully making.
Let me know if teh above are OK .. !
Mar 20, 2009 | Recoton Advent Advent Q1435A TV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
LG 5010 42" + Xbox360 + DVD RECIEVER/ Surround Sound SET UP HELP!
give me a shoult at our workshop. I'll give you a hand
SIon
0845 20 20 118
Mediarx.co.uk
Dec 12, 2008 | LG 42LG50 42 in. LCD HDTV
Help!!!!!!!!
Hook up Xbox360 to what, internet. Just plug the ethernet cable to the RJ-45 plug to your Xbox360 to your cable modem or router. If you mean you want to set it up, follow this link. http://xbox360.ign.com/articles/663/663050p1.html
Aug 25, 2007 | Microsoft Xbox 360 Console
Medion tv wont work
look at the components board the fuse holder is in and you will find a hot spot burn mark ...thats the component thats blown and shorted the internal fuse
Mar 20, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Microsoft Xbox 360 Slim Black Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
