I need the pairing code to install my Rebecca minkoff Bluetooth wireless keyboard and mouse for ipad2
I lost the user manual for my Rebecca Minkoff Bluetooth keyboard and mouse and am unable to connect to my ipad2
blackhearted
  • 30 Answers
SOURCE: Wireless Mouse and Keyboard Connection Lost
You might want to look into the settings on the wireless appliances they may be using a power saving setting. if they are wireless they run off batteries. Most devices now have a power save setting, most Mp3's do and most other decives as well check to see if this is the case, if not feel free to contact me and I will help you futher Thank You!
Posted on May 01, 2008
SOURCE: Dell bluetooth keyboard/mouse bundle
My wireless mouse and keyboard is not working right.
Posted on Oct 06, 2008
yooperbud
  • 8637 Answers
SOURCE: LOGITECH BLUETOOTH MOUSE
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Posted on Jan 20, 2009
  • 100 Answers
SOURCE: Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
Disconnect all devices from your PC including usb mouse and power adaptor.
Press power button and hold it for 20 seconds.
This will statically discharge teh PC. THen take out batteries from the keyboard and pres connect button to discharge keyboard.
When this is done connect pc to the mains and turn it on
Put batteries into keyboard and try to connect.
Press connect button on the pc first and then within few seconds press connect button on the keyboard.
Please leave your feedback if issue is solved or you need futher assistance
Posted on May 28, 2009
Imsian
  • 97 Answers
SOURCE: I hae a MI wireless keyboard and mouse but lost
hello,
Here is the link to download manual where you can find step to step directions
http://static.tigerdirect.com/pdf/Micro-Innovations-KB990W-UM.pdf
Posted on Sep 03, 2009
Pairing code of Sonay Vaio VGP-BMS21?
Try this
> (Go To) Control Panel > Bluetooth Devices
If your device is already there
Highlight device then in menu bar select Remove Wireless devise
Click on Yes
When device removed or if it was not there in the first place
> Add Wireless Device
When computer finds your device select it
Click on Next
Choose Pair without CODE
Click on Next.
Computer should then install drivers
This works with my Sony VGP-BMS33
Jun 06, 2014 | Sony VAIO VGP-BMS33/B
How to install keypad for my ipad2 keypad0713see200
if its a bluetooth key board go to the settings on your ipad turn on your bluetooth click find devicesand locate the key board tap on it and put in the pairing code (usually 0000 or 1234) that should allow you to pair your keyboard and ipad
Feb 27, 2014 | Apple Audio Players & Recorders
Hi: just purchased a solidtek ask 3952 bluetooth minin key board and cannor get it to work regardless of waht I do: have installed batteries correctly, turned power on, pressed pairing button but nothing...
what type of computer do you have and does it have a blue tooth receiver in it. if not you will need to get one, most pc's do not have blue tooth receivers although some do.
I just checked and that keyboard does not come with a reciever so that is most likely your problem. you need a receiver for your PC.
Mouse Included: NoPalm Rest: N/ANormal Keys: 88Operating System Supported: Windows 98/ ME/ 2000/ XP/ VistaPackage Contents: Keyboard User Manual 2 x BatteriesParts: 1 year limitedLabor: 1 year limited
Jan 10, 2011 | Solidtek Bluetooth Super Mini Keyboard
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
Jan 29, 2010 | Microsoft Wireless Entertainment 8000...
Wireless keyboard and mouse not working
Hello
Some wireless keyboards and mices have a button that enables the locating signal of the device, this button when pressed locates the receiver and initiate a pairing with the host. Look below you keyboard and mouse, and if your keyboard is a Bluetooth device, then check in your computer if the bluetooth is enabled and drivers are installed.
good luck
May 23, 2009 | Dell 0Y3740 Keyboard
Dell wireless keyboard and mouse will not work
Click NEXT.
Dec 15, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Installing a French ( Brand is Genius) keyboard to my Dell computer.
Pair to a Bluetooth Device (new and re-pair)
  1. Locate the Bluetooth icon in the lower-right corner of the computer screen, and compare the status to Table 1.
    (The Bluetooth icon may be hidden, click the Show hidden icons arrow to show any hidden icons.)
    Bluetooth Icon Status Enabled - The Bluetooth adapter is ready to pair with another Bluetooth device.
    Connected - The Bluetooth adapter is already connected to a Bluetooth device (if the desired device is not the one its connected to, it will have to be re-paired). Disabled - The wireless switch is off. For information on how to turn the wireless switch on refer to the
    Online User's Guide. None When no icon shows the Bluetooth driver needs to be installed, refer to Dell Knowledge Base Article:
    "How to Download and Install the Latest Dell Wireless Bluetooth Driver" Table 1: Bluetooth status
  2. Verify the following conditions have been met:
    • Batteries are Installed in the Mouse and Keyboard.
    • The Bluetooth adapter, USB Bluetooth adapter or 13/19-in-1 Media Card Reader is installed in or attached to the computer.
    • The latest version of Dell Bluetooth Wireless Keyboard and Mouse Bundle is installed,
      if unsure refer to Dell Knowledge Base Article: "How to Download and Install a Driver"
    • The Bluetooth device you are going to pair is within 30 ft. (10 meters) of the computer.
  3. Right-click the Bluetooth icon in the system tray.
  4. Click Add a Bluetooth Device.
  5. Turn on the Bluetooth mouse and press the Bluetooth connect button on the bottom of the mouse. The Bluetooth LED on top of the mouse should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  6. Click Next to start searching.
  7. Click the icon for the mouse to highlight it and then click Next.
  8. The connection is set up automatically. Once the connection to the mouse has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the mouse indicates it is connected.
  9. SetPoint will now launch and ask to check for updates, click OK. If an update is available click to download it.
  10. After the update has been applied, click OK.
  11. Turn on the Bluetooth keyboard and press the Bluetooth connect button on the bottom of the keyboard. The Bluetooth LED on top of the keyboard should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  12. Click the box next to My device is set up and ready to be found and then click Next to start searching.
  13. Click the icon for the keyboard you want to connect to in order to highlight it and then click Next.
  14. When the keyboard is connected, the Confirm Keyboard Connection screen appears. A passkey that has been generated for the keyboard is shown. Type in the passkey as it is shown on the screen. Note:
    The keyboard can only store one passkey. The passkey is unique to each computer. If you try to connect the keyboard to more than one computer, the passkey is changed each time you create a connection.
  15. The connection is set up automatically. Once the connection to the keyboard has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the keyboard indicates it is connected. You are now be able to use the devices.
Aug 25, 2017 | Trust Silverline Direct Access 12879...
Pairing WOM20 with Computer
i think you may be getting wireless confused with bluetooth. Your mouse is wireless and it needs the wireless sender unit connected to a usb port, but this is not bluetooth, it picks up the wireless signal from the sender to work. You will also need to install any software that you got with the mouse (if any), as you will need to set up the button and click functions, unless it just uses the normal pointing device driver in windows.
Apr 25, 2007 | Dynex DX-WOM20 Mouse
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
