Question about Homelite Garden
Homelite super xl 925 gas mix ratio - Homelite Garden
  • 104 Answers
SOURCE: fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
Posted on May 23, 2009
  • 376 Answers
SOURCE: what is my lo hi carb adjustment for a homelite
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Posted on Jul 01, 2009
dontbother10
  • 2220 Answers
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 28, 2009
dontbother10
  • 2220 Answers
SOURCE: homelite super xl ao runs for a short time, then
Inspect your cylinder and piston as follows:
A written diagnosis by a good independent saw shop ($10-20 I recommend Stihl) might be a good idea at this point.
1. Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
2. Is the saw equipped with a decompression valve? Yes continue, no proceed with 3.
· Leave the ignition off, set the valve and pull the starter.
· Pull gently to release the valve. Is there a difference in the effort required?
· If yes continue with 3, if no repair or replace the decompression valve.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including; leaky intake connections at the engine or carburetor; leaky crankcase seals; or running on gasoline containing no 2-cycle oil.
· Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
A short block R² is the usual repair homeowner grade saws. You may find some additional help here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Please do a search for your saw before posting any question.
Posted on Jan 15, 2010
dontbother10
  • 2220 Answers
SOURCE: Have an older XL 16
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/87d4d17cf11a7c8b88256c280064b0b8?OpenDocument
XL-12 and 15 agree with your mixture, no 16 listed.
32:1 = 1 gallon of premium fuel to 4 ounces of quality 2-cycle oil.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 19, 2010
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I have a HOMELITE XL-12 chain saw. Web sites say it takes a mix of oil and gas. But mine has a place to put oil in. Which should I do?.
The mix of oil and gas should be a 32:1 ratio which is 4 oz. of oil to every gallon of gas. I am assuming that what you are seeing is the oil tank for the bar oil. You need to use bar and chain oil for this tank as it is what keeps the chain lubricated. Do not use two cycle oil for the tank marked oil.
Apr 15, 2011 | Homelite Garden
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
Feb 20, 2011 | Homelite Gas, 20 In. Bar, 46 CC, Chain...
What fuel mix does a homelite xl-130 chainsaw require?
the homelite xl-130 gas/oil ratio is 32:1 meaning one quart of gas and one oz of 2 cycle engine oil or one gallon of gas and and one 4oz bottle of 2 cycle engine oil.
Best,Regards
obliqueridge
Nov 10, 2010 | Homelite Garden
XL UT # 10655A Serial # HL1490086 XL 2 Serial # 40152376 Recently bought these 2 saws and have gotten 3 answers for the gas/oil mix. Can you tell me what is the right mix??
Run what ever fuel/oil mix you are comfortable with. A run lean condition is most often caused by an undetected air leak leaning out the mixture to failure. A couple of ounces of 2-cycle oil will not prevent its occurrence. If an owners manual (OM - I tried) is ever located it likely says 32:1. Most modern saws recommend 50:1:
Oil Mix Ratio:
In the early to mid 90s Dolmar, Echo, efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 18, 2010 | Homelite Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Have an older XL 16" Homelite chainsaw UT10695, Ser. No. HO0681042. Can't find manual for gas/oil mix ratio, thought it was 32:1??
Lou
Mar 19, 2010 | Homelite Garden
Garden Logo
177 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
