Question about Nintendo Game Boy Advance SP Console
When I plug the charger into the ds, an orange light flashes once then turns off.
Not sure of how long ago the ds was charged. Does it take a long time to charge if it hasn't been charged for a long period of time?
SOURCE: ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
After a bit of trial and error I found that one of two internal fuses had blown. You can bridge the fuse with a bit of solder to fix it but this means if the same thing happens again there will be no fuse to protect your DS. My own solution is to get a friend to charge my battery on their DS while I wait for a desktop battery charger to arrive from Hong Kong. I found the battery charger on ebay. I suggest you charge your battery in a friend's DS and put it back in your own to see if you DS works. If it does then you have the same problem as me.
Hope this helps.
Posted on Jan 14, 2008
SOURCE: nintendo ds lite will not turn on, when trying to charge the orange lite blinks once.
after researching this for a while, i heard that it is because the fuses have blown inside the ds. you can try to fix it but it is risky.
good luck!
Posted on Feb 22, 2008
  • 56 Answers
SOURCE: Orange light briefly comes on and DS does not charge
is the charger socket ok as i understand they snap internaly also could be worth checking the battery.
Posted on Jun 27, 2009
rulds2008
  • 3866 Answers
SOURCE: DS Charging Diffuculties
( times out of 10 here its the battery if by replacing the battery it still does not charge you got a bad charging unit inside the DS and your repair bill will be under $75 bucks to replace the chargin element inside.
Like my advice please accept and rate it today. We accept all postive answer ratings , Thanks.
Posted on Oct 09, 2009
Testimonial: "thanks"
  • 17 Answers
SOURCE: DS Lite does not power up
If the console has overcharged or has been used for long periods of time or could just be fluke, chances are the fuses are blown on the main motherboard try this link, this guy fixed my ds and i had the exact same problems as you guys have
Posted on Mar 14, 2010
My ds lite turns on but it will not charge. It's not the battery or the charger. I have tested the fuses with a multimeter and both fuses read 0 ohms. The orange charge light does not flash briefly when I...
You can try buying another battery, or by buying a charging station that could just charge your battery (incase its the charger port on the ds thats broken).
Feb 28, 2011 | Nintendo DS Lite Console
My DS lite wont charge - the orange light flashes once, then nothing.
Hi, it might be the fuse.
Does the DS turn fail to turn on?
Does the charge light just flash briefly when you plug in charger?
If so it will be the fuse.
If the console it out of warranty, maybe you or someone you know can fix it.
Check out the following youtube videos
Good Luck
http://www.youtube.com/watch?v=io5iN42q3VQ&feature=related
or for an easier but dodgy method
http://www.youtube.com/watch?v=GYWt811XNDs&feature=related
Jan 24, 2011 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
My ds wont charge the orange lite wot turn on and the charger slot on my ds is wied looking
my ds lite wont charge i get a flash of the orange light then nothing can you help me please
Jan 05, 2010 | Nintendo DS Lite Console
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
When plugging power to the DS lite the led flashes orange once
I think if the orange light flashes once it means it has a full charge.
Mar 18, 2009 | Nintendo DS Lite
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Feb 28, 2009 | Nintendo DS Lite Console
Ds is plugged into charger. But when i try to
What is the orange charging light doing? If it is just flashing on, or only staying on or a minuet, that means you need a new battery. The orange light foes on when the battery has been charged to its maximum capacity. After each charge, the capacity is decreased. So if the orange light is on for only a short time, get a new battery.
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Ds nintendo will not charge light flashing and think it is the connection on the ds as i have tried other chargers in it
um.... im jut asking dose it flash green, orange or red? if it flashes green it is fine if it flashes orange its giving you a warning then if it flashes red that is when you charge it oui? but if it flashes red and you still cant charge it well i ont know what to tell you? oui, no, maybe? wll if i didn help sorry but i tried. sorry or your welcome which ever best fis your dicription. †
Dec 01, 2007 | Nintendo DS Console
Nintendo Game Boy Advance SP Console Logo
78 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
