Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
LG DISHWASHER LD-12AW2
MY DISHWASHER FILLS WITH WATER AND THEN STARTS BEEPING WITH CODES AE AND NOW 1E FLASHING PLEASE HELP?
  • 640 Answers
Ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Posted on Feb 04, 2009
Model LD 12AW2 not drawing water displaying 1E error
Hi afarugia,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 10, 2011 | LG Dishwashers
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
1E error LD-14aw2
I do not have specific info on your model, as I believe it is one not intended for USA distribution (where I am at) but, you might want to check the following, which applied to some LG dishwashers produced between Jan or 2005 and Feb. or 2007.
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Aug 25, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
My LG dishwasher, model LD-12AW2 runs for 10 - 15 mintues and then goes into a H and flashing 'E' fault. This fault isn't listed in the manual.
Happy to be of some help. Please keep this list around so you can take notes if the problem comes back.
Good Luck!
Apr 13, 2009 | LG Dishwashers
LG LD-12AW2 ( Not 12BW5 ) Error code E3 shows.
WTF, do you have any solution on this stinking website
Sep 06, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG LD-12AW2
this unit has an anti flood device. if it leaks it lifts a piece of plastic in the base and hits the microswitch. try leaning the unit to one side and i would put towels down. if water comes out then try a program. hope this helps.
Feb 12, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD12AW2 leaking
The fill switch may be contaminated with soap or debris that makes it heavier and makes it float lower in the water which means more water is required to trip it. Try moving it manually and see if it is hard to move at the top of its travel.
Oct 28, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
693 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
