Question about Hoover Vacuums
Beater bar bearing lubrication
What should be used to lubricate the bearings on a beater bar? Will oil get gummed up from all the dust? Could graphite work?
  • Hoover Master
  • 18,424 Answers
Normally the bearings in brush-bars are sealed bearings with a dust cap on both sides graphite would be best,, but the best bet is get two new ones off EBay there very cheep to buy,,,
Posted on Jan 03, 2013
SOURCE: bad bearing on kenmore whisperbelt beater brush.
Sorry,
I thought this was a free forum. I do not intend to hire a bunch of experts to find out if a bearing can be found for my vacuum cleaner when the entire brush assembly in $39.99.
This is a very tricky way to get unsuspecting people sucked into paying for something they thought was free.
Bad business, sorry.
Posted on Dec 31, 2008
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
  • 172 Answers
SOURCE: beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Posted on Mar 02, 2009
EwingElect
  • 276 Answers
SOURCE: beater bar motor will not engage
Check your clutch to make sure it's engaged. There should be a knob on the foot of the vacuum that can be turned to stop the roller.
Posted on Mar 22, 2009
  • 8 Answers
SOURCE: Beater Bar Quit Working
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
Posted on May 25, 2009
Tornado cv30
Sound like the beater bar is full of hair and other debris causing
the motor to be under too much of a load. Extract the beater bar
and clean it. The bearings at each end may also need to
be lubricated or replaced. The should turn real easy.
Oct 16, 2013 | Broan-NuTone Vacuums
How do I take the agitator end caps off?
Alliemay657:
It sometimes takes a 2 grunt pull to remove the end caps and bearings from the agitator (called the beater bar). I have had to use a flat blade screwdriver to CAREFULLY pry the end caps and bearings from a beater bar. Be careful not to stab your hand with the screwdriver (It HURTS!!!) Once you get the end caps and bearings off, clean the hair and carpet fibers from the ends of the beater bar and bearings and end caps. If the bearings don't turn easily, dribble some rubbing alcohol on them (I use a spray bottle filled with alcohol) and spin them until they spin freely. Dry the bearings until there is no alcohol in them. Put a drop or two of light machine oil in each bearing (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure they spin freely. Now would be a good time to check the vacuum head and hose for clogs. Push the bearings and end caps back on the beater bar and reinstall the beater bar (with a new belt). Reinstall the foot plate, and your machine should run like new
Feb 15, 2013 | Dirt Devil Breeze Bagless VacuumVacuum
Vacuum doesnt pick up very well any more
Larry Kessler:
Unplug the vacuum and lay it down on the floor upside down on some newspaper. Remove the vacuum head foot plate with a Phillips head screwdriver. Remove the beater bar and belt by pulling straight up on the beater bar. Pull the end caps and bearings from the ends of the beater bar... it may take a two-grunt pull to remove them, or CAREFULLY use a screwdriver to pry them off. Remove the hair, carpet fibers and other gunk from the ends of the beater bar, bearings and end caps. Pour (or spray) alcohol on the bearings and spin them until they spin freely. Dry the bearings so there is no alcohol in them.
Put a few drops of light machine oil in the bearings, (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure the bearings spin freely. Now would be a good time to check the vacuum head opening and the hose for clogs. Reassemble the end caps and bearings to the ends of the beater bar and reinstall the beater bar assembly (with a new belt) in the vacuum head. Reinstall the foot plate, and your machine should pick up fuzz balls the size of Michigan!
Feb 15, 2013 | Vacuums
It smells like it's burning when I vacum/what's wrong with it
Tammy May:
Unplug the machine and remove the foot plate (at the bottom of the vacuum head) and check the belt that drives the beater brush/bar. if the beater bar is hard to turn, pull the beater bar and belt out, check the inside circumference of the belt to see if the motor shaft has worn it down in one spot. If so, remove the two bearings (one at each end of the beater bar) and remove the hair, carpet fibers, strings and any other junk from the bearings and the ends of the beater bar. lubricate the bearings with oil (thin machine oil like 3 in 1 oil works best. roll the bearings with your hands until they spin freely. Now would be a good time to check the bottom of the foot plate where the dirt is vacuumed up. check the hole in the middle of the foot plate and check the hose for clogs if the hole and foot plate hole are clear, reassemble the bearings on the beater bar and install the beater bar (with a new belt) and reinstall the foot plate. The machine should run well for you.
Jan 19, 2013 | Eureka Vacuums
Roller will not turn
Conmaur102:
I don't know what type of vacuum you have, but you should check the drive belt to see if it is damaged. Remove the sole plate (at the bottom of the head) and remove the belt and roller (called the beater bar). check the bearings at each end of the beater bar (they must roll easily and smoothly). If they are bound up, pull them off of the ends of the beater bar and remove the hair, strings, and fibers wound around the end of the beater bar. Lubricate the bearings with light machine oil, and spin them by hand until they spin freely. Reinstall the belt and beater bar, and reinstall the sole plate. While you are at it... check the hose and head to make sure they are not clogged.
Jan 06, 2013 | Vacuums
Z61 brush won`t rotate belt ok
Hartlepoolke:
Unplug the vacuum, turn it upside down and remove the floor plate so you can access the beater bar. Remove the belt from the motor shaft and remove the beater bar and belt from the machine. At each end of the beater bar there will be a small circular bearing. Carefully remove the bearings from the ends of the beater bar, and remove the collection of hair, carpet fibers and any other junk wrapped around the bearing mount studs. Grab an old pan... (something to wash the bearings in) and an old toothbrush. Scrub the bearings with the toothbrush dipped in rubbing alcohol, and attempt to spin the bearings by hand as you clean them. When the bearings will spin freely, dry them out, and put a drop of oil (preferably 3-in-1 or light machine oil in the bearing. Don't soak the bearing in oil, that will just attract more junk to jam the bearing. Wipe the bearings off and rotate them to ensure that they aren't ratcheting or siezing up. Check the belt to ensure that the motor spindle has not damaged the inside surface of the belt... If it has, a new belt may be in order. Reassemble the vacuum and you problem should be solved.
Aug 26, 2012 | Electrolux Vacuums
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
The beater bar will not turn. I have cut all the hair and lint off but it still will not trun.
is the belt broke ? also try taking the beater bar off the vacuum and then checking the end roller bearings. clean and lubricate with some light oil. make sure belt is solid.
Dec 17, 2010 | Vacuums
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
698 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
