Kitchen aid dishwasher model KUDS24SE not cleaning well
smilemaker
  • 790 Answers
SOURCE: broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
Posted on May 07, 2008
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
Kitchen Aid Sculptura not pushing water up to dishes in order to clean.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Jan 04, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
I have a kitchen aid KUDS24SE dishwasher that I believe has a piece of glass stuck in the chopper. How do I get to it? I have the impeller out is there a repair manual online somewhere?
there will be a screen inside pump where food chopper sit here is a link showing the full schematic for your dishwasher piece by piece taken apart just choose the section and examine the sump area and you will be able to see how to get to the chopper If you have any further questions message me back and please remember to rank this opinion as to how it helpedin your appliance situation Thanks again
Rick
heres the link
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS24SEWH5/0593/0130000?searchedModel=KUDS24SE&blt=
Dec 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
KITCHENAID dishwasher will not dry the dishes
kitchen aid mod kud101dl does not clean dishes well. lot of scum on door.
Feb 26, 2009 | KitchenAid Dishwashers
Kitchen aid dishwasher doesn't clean dishes in the top rack
Nov 25, 2008 | Dishwashers
Can,t opendoor on kitchen aid dishwashr
send me an email ihave apage to send you b4829@yahoo.com under subject put kitchenaid door
Jan 15, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
15 people viewed this question
k24674
