PK5001Z ZYZEL VPN DROPS CONNECTION PROBLEMS - Computers & Internet
3 Suggested Answers
SOURCE: BR6104WB problems with VPN connection
Hello I am having the same problem at the moment, i understand the problem but every attempt i try at opening the specific ports it does not work. The Nortel networks VPN client is supposed to use port 500 TCP and 500 UDP but still not working.
If you discover the problem please could you post the answer on here.
Thanks
Paul
Posted on Jan 26, 2008
SOURCE: Edimax BR-6574n wifi VPN connection problem
I have reseted the router configuration back to Factory Default, and set it up again from the beginning. I think the problem was at the firewall settings.
Posted on Aug 25, 2009
PK5001Z speed drops jitter and latency
Try dropping your MTU setting down to 1492 or maybe a little lower if you're trying to use QoS or something like that. That will cut down on packets becoming fragmented for being a little too large.
Nov 20, 2012 | Computers & Internet
Tip
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
on Sep 14, 2015 | Apple iPad Tablets & eReaders
I have a Zyzel nbg416n wireless router. Ive had it for 5 days and its constantly dropping the connection. Connection via an ethernet cable is fine, it's just the wireless aspect. The connection...
Wireless routers do what is called signal shifting. This means as the signal gets weaker (either because of distance or because it has to pass through walls, strong electrical fields etc) the speed is automatically dropped to as low as 6mbps. All the obstacles will kill your signal very quickly as well. You can try moving your router to a better location or invest in a repeater to place between your wireless router and the computer.
Sep 15, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Aug 24, 2009 | Edimax PRI-682 Router (PRI682)
VPN Connection problem with DSL
contact your ISP and ask them to enable IPPAssTHROUGH on your system.
make sure the ports::
TCP 10000
UDP::500, 4500 should be open
Mar 30, 2009 | SonicWALL Global VPN Client for PC
I have VPN connection, but it is not connecting in to VPN, but connecting broadband only. please help me how to configure VPN network from Broadband. Total Treasury department in Srikakulam District using...
there might be some problems and you have to go through them.
--> check the cable
--> check the vpn connection settings
--> check the server name
--> check the user name and password (it should be same as of your system in office
--> make sure your computer is on at work
i hope this will help you
if none of them work then the easy way is to make other connection that will definitly do
Mar 24, 2009 | Sony VAIO FX150K Notebook
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I'm having problems running programs on my HP pavilion dv2000. The programs having problems are: Google Chrome setup Firefox 3.0.1 Nortel Contivity VPN The problem is that all 3 programs cannot...
The problem looks with the Nortel VPN. VPN software blocks all other Internet connections when started. This way they create a secure, encrypted tunnel from your pc to the destination pc and does not allow the other connections -Firefox, Chrome etc- to perform. The non performing Internet applications mean less threats online (e.g. nobody can exploit a flaw in Firefox and reach your VPN connection).
If the problem is that the browsers do not function even after you stop the VPN connection, it may be that the VPN software is still running in the background. You can make Ctrl + Shift + Esc to bring up the running processes and see if the VPN is running in the background. If yes, turn it off.
Sep 15, 2008 | HP Computers & Internet
CANT GET VPN CONNECTION
the vpn connection from your home to work or the vpn connection from anywhere else to your home by vpn.
here you find a forum with the same problem:
http://broadband.motorola.com/consumers/support/faqs/surfboard_faq.asp#cant_login_vpn
Dec 07, 2007 | Arris SURFboard SBG900 (49402201900) Modem
VPN connection problems!
I am not real versed on VPN connections but the only way I was able to connect to my company's Cisco VPN using my Ipaq was with this program. http://www.apani.com/vpnclients.html The whole thing went very easily.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
