Question about Pioneer VSX-1022-K Network Ready Receiver
Vsx 1022 k wont power on
I just received receiver as a gift. I'd like to troubleshoot without letting person who bought it know about it. I hooked up the receiver and it worked fine for a few minutes. But when I hooked up my son's iphone, only one speaker was working. Then it shut off, and won't power back up. Is there anything simple a layman can check himself, such as a fuse?
  • 13 Answers
SOURCE: overload
I know that this post is long outdated, but I came across it and had to post.  Sorry, but the solution posted by nfanres is not correct.  Just because the KLH speakers are rated at 250W does NOT mean that they will always pull that much from the receiver.  That is just a manufacturer rating saying that they recommend supplying a max of 250W to the speakers.  The reason your receiver says "Overload" is most likely due to the subwoofer being an improper impedance for the receiver, causing the receiver to see a lower resistance in the load, and thus outputting too much power.  I could go into a detailed explanation as to why with Ohm's Law, but just suffice it to say that if you decrease the resistance, current will increase, thus the overloading (too much current draw for the receiver).
If you haven't already, try just unhooking the sub and going back to the setup you had before.  Generally, Pioneer receivers are protected, and just say "Overload" and shut down everything so that nothing fries.  If you have already tried that, then I don't know what to tell you - something must have internally tripped.  You have probably either gotten rid of the receiver or fixed it by now, but I just had to post and clear this up for anyone else who might have a similar problem.
In short, ratings on the backs of speakers do NOT mean that they pull that much power.  It's just a rating of how much you can push from the receiver to the speaker.
Posted on Dec 25, 2007
SOURCE: stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Posted on Jan 12, 2008
  • 899 Answers
SOURCE: VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Posted on Oct 07, 2008
SOURCE: receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Posted on Dec 31, 2008
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
Posted on May 02, 2009
I have a Pioneer VSX-1022 Reciever - I get no sound when it is on the "TUNER"
These models have a problem where it is very easy for the tuner pcb to become disconnected from the main pcb. About the only way I've found to fix it, is to take the back panel completely off and reseat the board.
Apr 11, 2013 | Pioneer VSX-1022-K Network Ready Receiver
Shuts off and on the tv
its your wiring in your house. the initial draw is to much for your wires. pplug the tv into a totally different socket and see if it fixes it
Mar 13, 2013 | Pioneer VSX-1022-K Receiver
Sound cuts out on one channel while playing LP records VSX-1022
you have a short in the rca cable from phono to reciver. try a new cable. if problem is still there i would say your record player is shorted inside.
Mar 13, 2013 | Pioneer Vsx-1022-K 7.1 Home Theater...
Pioneer VSX-40 won't power on
check the fuse or ic regulator
Feb 26, 2013 | Pioneer VSX-D307 Receiver
I've just bought the pioneer vsx 921 receiver with
The company's advertisement says it all. The company has mentioned the receiver as "Industry's First AV Receiver Designed for iPad". So it cannot compared with TV.
May 05, 2012 | Pioneer Audio Players & Recorders
Power cable for pioneer vsx-d712
Take your unit to radio shack .
Almost guaranteed they'd have a match.
Godspeed,
Scott
Jan 08, 2009 | Pioneer VSX-D712 Receiver
Standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Need a user manual for my Pioneer Elite VSX-07TX
I have this receiver, and just scanned the manual for an individual. If you still need a copy of it, let me know and we can figure out how to get a copy to you. Regards, Berry bcaddell@icsystems.net
Nov 11, 2007 | Pioneer VSX-07TX Receiver
Pioneer VSX-1022-K Network Ready Receiver Logo
466 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
