Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Torque pattern for Briggs & Stratton 313707 OHV head bolts
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs & Str... Master
  • 1,917 Answers
Its a criss cross patern dont over tight they will break off when running make sure of your tork on them
Posted on Jun 23, 2014
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
freetek
  • 5568 Answers
SOURCE: briggs & stratton with idle problem
This is not unusual at idle; there is a governor to limit maximum RPMs and this device isn't worth beans at an idle.
You may be able to carefully adjust the idle adjustment (see your manual or B&S website) to achieve a somewhat more even idle speed.
Posted on Aug 20, 2009
  • 17 Answers
SOURCE: craftsman 19.5 lawn tractor w/briggs & stratton keeps flooding
This could be a number or items from no spark to a faulty carburetor, a plugged up air filter, valves out of adjustment, poor gas, faulty spark plug.
First, see if your getting spark, how about taking the wire off a plug(s) and holding it about 1/8" or so away from the plug with some masking tape while you crank the engine. You should be able to see the spark jumping the gap, it helps if it is not too light outside. If you attempt to do this with your hands, you will get a spark jolt, it hurts, so use the tape and remember, the engine could start so proceed with caution.
If you have no spark there, then you ignition or magneto is faulty. This would be unlikely in the broader scope of things. You will likely get spark. Make sure the plug is clean, take it out and inspect. If it is covered in gunk well clean it. It will smell like raw gas but you already know that. Change the plug if in doubt.
Remove and clean and replace the air filter.
If you have spark, and a clean filter it is likely a carburetor problem, Depending on the carb, it could be the choke is faulty or, as per the below.
Depending on what model you have there is a float assembly in the carburetor that stops the fuel from flooding the carb and air intake. The gas tank is higher then the carb right, so if you dont have a mechanism for stopping the fuel from leaking out the hole that goes into the engine, it will all leak out right, as into the fresh air intake because its easier than going into the engine. So, there is a miniature float assembly, sort of like your bathroom toilet float to stop the water. Well there is a small wedge type needle that seats into a hole and it is attached to a float. As the gas rises in the bowl, it pushes up the float, sealing the gas into a chamber, as you use more gas, the float lowers and more gas goes in. So ,there is dirt jammed into the float bowl sealing needle, just a little, thats all it takes. So, shut off the gas somehow, hopefully you have a valve, or squeeze the rubber line, then undo the float chamber, its one nut on the bottom. Clean carefully. The needle, little spring and float assembly are delicate. Also, the needle could be worn from engine vibration, so it may need a new needle. It would help if you described the engine and carb though.
I posted that as a solution to another problem, but yours may also be the valves need adjusting. Depending on the amount of hours, say over 200, then the valves timing will likely be off a bit. Check the clearances with a feeler gauge, it is not as difficult as it seems. Check your Owners manual for the clearance at top dead center. TDC is when you take the plug out and watch the piston arrive at the top of the cylinder through the spark plug hole when you are turning the engine over (do this by hand, battery off. Make the adjustments with the valve cover off. Follow the instructions.
Hope some of this helps.
Posted on Sep 21, 2009
  • 61 Answers
SOURCE: My Briggs & Stratton Quantum 65 starts
Do a compression check when cold, then again when hot. Sounds like when its hot your losing compression. If this is the case, it won't want to start when hot. Compression should be above 60 lbs. Thats where i would start. I hope this is of some help to you.
Posted on May 29, 2010
Testimonial: "Prompt and useful help. Thank you."
  • 252 Answers
SOURCE: NEED TORQUE SETTINGS FOR 18 HP MODEL
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Posted on Aug 17, 2010
Torque spec on 21 hp briggs and strattonand sequence
Doug, Torquing multiple bolts, like on a cylinder head are shown in last video link.Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
FAQ Small Engine Specifications Briggs Stratton Specs
Engine mounting pattern
HOW TO LOOK UP AND TORQUE BRIGGS HEAD
How to replace Briggs Stratton Intek Head Gasket Pt 2
Jun 01, 2016 | Cars & Trucks
What are the torques on a 22hp ohv briggs and stratton head and also push rods
VERIFY your engine model numbers
Briggs & Stratton Intek V-Twin
Engine Model Numbers 407777 and 44P777
Cylinders 2 (Dual cylinder)
ITEM N m (Newton metres) lb-in Spark Plug Torque 20 180 Back Plate (to cylinder) 11 100 Blower Housing Screws 9 80 Breather Screws 6 55 Carburetor to Manifold 7 65 Cylinder Head Bolts 25 220 Cylinder Shield 7 65 Crankcase Cover 23 200 Engine Mounting Bolts 48 35 lb-ft Electric Clutch Mounting Bolt 75 55 lb-ft Exhaust Manifold 16 140 Fan Retainer Bolts 16 140 Flywheel Nut 203 150 lb-ft Armature Mounting Screws 3 25 Intake Manifold Bolts 9 80 Rocker Arm Adjustment Lock Nut 7 62 Rocker Support Screws 11.3 100 Valve Cover Cap Screws 11 100 Carburetor to Intake 7 65 Valve Clearance (Cold) 0.10-0.13 mm (0.004-0.005 in)
WARNING: Uneven tightening will warp the head. Tighten Cylinder Head Bolts down evenly by hand. Then using torque wrench tighten in sequence, in 9 N m (80 lb-in) increments to 25 N m (220 lb-in).
Intake valve push rods are aluminum.
Exhaust valve push rods are steel.
DO NOT interchange push rods.
Removal and Re-installation sequence for bolt removal and tightening.
Mar 21, 2015 | Garden
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Need to know the torque sequence for my briggs & stratton 6.25hp craftsman push lawnmower engine?
One method that works is to use a star shaped pattern and torque the bolts in 2LB increments. Be careful not to overtorque the bolts.
Jul 15, 2014 | Briggs & Stratton Garden
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
498 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
