Question about Brugnetti Simona Top Espresso Machine
Very noisy and little or no water comes out
Has been getting worse, the noise and very little or no water comes out. Has plenty of water in tank. Maybe pump failure? Can i get parts here in Australia? or is not the pump, maybe other problem?
Water not pumping from the tank
If the pump is primed, water will come out of the tank when the pump is running. It make take a little time for the tank to fill, but you should hear the pump making some noise. An un-primed pump just makes a motor noise, not very loud.
Aug 12, 2015 | Plumbing
My cheverolet Metrol Lsi water tank cannot hold the water in it. I have to refil the water every 30 minutes. What do I do?
first check if theres any water leaks from your water lines and your radiator. if not try to replace the thermostat. worse comes to worse you have to change your water pump...i hope this helps a little
Jan 29, 2012 | 2001 Chevrolet Metro
Little noise coming from the engine when idling.
Where is the noise from exactly? It sounds like clutch basket rattle, often happens when idling, worse when cold, not so bad as engine warms up. If it's from the top end it's probably tappets. Change the oil if you haven't recently done so and see if that helps. clutch basket is no problem unless it gets REALLY noisy and gearchanges are difficult, then change clutch plates and clean up basket. Tappets or shims will need to be done at next service so performance will be maintained, if it's top end.
Jul 02, 2011 | 1993 Honda VF 750 C Magna
Why does my self cleaning gas water heater make clicking noises?
zdriscoll-
All tank water heaters make some amount noise, clicking and "snapping" sounds, particularly after much of the hot water in tank has been used (like after a long shower) and has been replaced by cold water that is being heated vigorously.
If the noises are accompanied by poor or erratic performance, or obviously if something malfunctions, you may require the services of a repair connection.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Noisy Transmission getting worse.
Does it still move? Make sure you don't have a stick or something stuck in the transmissions pulley/fan. Check idler pulley's too.
What kind of noise?
Sep 03, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Metal rattling noise when low idling
sounds like it is most likely an exhaust heat shield. they make alot of noise and the simple soution is to get under the car and hit them to see which is the culpret and then rip it off
Jun 26, 2009 | 1997 Honda Accord
Nissan xterra 2003 car noisy problem
If it's the water pump there should be water leaking, if it's the steering pump the noise  would change as you turn the steering wheel left to right. If it's constant, it could be just old belt and bad idler and tension pully. Start buy praying a little water to the belt while the engine is running and if the noise goes away, the belt is in time to be chaged. If the noise is still there, then most likly it's the ilder bering or tension bearing. Good luck
Apr 08, 2009 | 2003 Nissan Xterra
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
1995 318ti
HI there,
Your car is fitted with one very long belt which we call serpentine. Actually you cant adjust this belt as it has an automatic tensionner.
Try this, pour a little bit of water on the belt while the engine is running. If the noise stops then you know it's the belt which is noisy. If this is the case, a replacement of the belt is advised.
If not it means that probably the A/C compressor or the tensionner is faulty.
Cheers.
Aug 24, 2008 | 1997 BMW 318
Open Questions:
Hello, I have a Brugnetti MC-1 Espresso Machine. It had not been used for a couple of years and then I tried to make some espresso with it one day. I plugged in the machine and everything seemed to be working fine. I waited for the machine to reach the recommended temperature prior to pressing the brew button and to my surprise the water started coming out of a small hole located on the procon pump. When I inquired about what the problem may have been, I was told that the pump had become stuck due to the machine not being used for a while. I took off the procon pump and effectively, the little axle on the procom pump which has a notch that receives the electrical motor that drives the pump was stuck. I took a pair a pliers and tried to get the axle unstuck on the procon pump by manually turning the axle and sure enough it became unstuck however, as I kept spinning it with my fingers, every once in a while it seems to get stuck again but not to the point that I need a tool to get it unstuck, I just have to turn it a little harder with my fingers. For this reason, I decided to purchase a new procon pump and switched out the old one for the new one. I've been doing some research as to what needs to be done when one swithces out the pump and in that research I came across a recommendation that the water solenoid needs to be opened in order for the tank/ boiler to fill up and I don't know how to go about doing that since my main concern is not doing more damage to the machine. I would also like to know what needs to be done to the group components in order to maintain it in optimal working condition. I've already removed a small screen on the the group head and cleaned it out thoroughly as well as a nother piece made of brass which the screen screws on to. If anyone could provide any expert advise, experience, suggestions or guidance as to what to do after replacing the pump and prior to turning on the machine again as well as regular maintainance on the machine, it would be greatly appreciated. Best regards, Richard Granados
Aug 07, 2011 | Brugnetti Simona Top Espresso Machine
See all Brugnetti Simona Top Espresso Machine Questions
Brugnetti Simona Top Espresso Machine Logo
Top Brugnetti Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Brugnetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
