Question about Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
My Panasonic SA-HT680 will not turn on - Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
  • 4234 Answers
SOURCE: sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Posted on Apr 09, 2008
  • 514 Answers
SOURCE: Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Posted on Jan 11, 2009
smarthome2
  • 1114 Answers
SOURCE: CD/DVD PROBLEM ON A PANASONIC SA-HT680
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
Posted on May 22, 2009
SOURCE: Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Posted on Jul 17, 2009
My Panasonic sa-ht680 will play back round sound but no voice and when I try to change the surround it says error
Some sound systems have the option to switch off the Centre Channel. That might have happened here. But it could be a fault.
Jan 09, 2016 | Panasonic Audio Players & Recorders
The remote control for my Panasonic SA-HT680 was totally destroyed by 6 year old son (Boys will be boys). I want to replace it with a genuine replacement. Can anybody help me? I have also had the problem...
You can call Panasonic at 1-800-405-0652.
Be ready to give them model and serial numbers to find out availability of replacement remote.
Good luck ( with the remote and your son) !
Nov 29, 2010 | Panasonic SC-HT680 System
I need a code for dvd panasonic home theater SA-HT680 for sony rm-y181 thanks
Future reference, go to www.Sony.com or even google. The users manual is available online and you can get the codes there.
However, I was bored so I looked them up for you.
the code is 753
Jun 11, 2009 | Sony RM-Y181 Remote Control
May 21, 2009 | Panasonic SC-HT680 System
Jan 11, 2009 | Panasonic SC-HT680 System
Bit rate showing at top of screen
is it possible to play my cable tv through my system
Dec 03, 2007 | Panasonic SC-HT680 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
Nov 19, 2006 | Panasonic SC-HT680 System
57 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
