Question about Frigidaire FRS26R4A Side by Side Refrigerator
No water at door - Frigidaire FRS26R4A Side by Side Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello stolnvette - I suggest checking that the water valve is completely open (usually located on the back of the unit). When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. A clogged water filter or a blocked supply water valve may also lead to no water to the dispenser.
Posted on Jan 06, 2013
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Leaking from motor
Water Inlet Valve
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Seal
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
GE MODEL # PSS25MGN water wont dispense on door ice maker works
Your water line could be frozen inside the freezer door. Open your freezer door and remove the kick plate on the bottom of the unit. Follow the water line from the door under the unit and it will be clipped under the unit. Pull out the water line and disconnect either line from the coupler (push the water line in and hold the ring then pull out the line). After you do that close the door and try the water again, if you get water then you will need a low wattage heater for the door.
Mar 14, 2013 | Refrigerators
Water on door wont dispense
Mar 14, 2013 | GE PSS25MGN Side by Side Refrigerator
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
No water flowing from filtration port even after changing the fridge filter and also checked rear tubing and their is no clog.
Hi and welcome to FixYa, I am Kelly
Check to door switch at the top of the freezer door hinge (left) and make sure the switch is being actuated when the door is closed. If you have ice production and only the water in door is not working then the most likely failure is the inlet water valve solenoid for the water in door only. There are 2 solenoids. 1 for the ice maker and 1 for water in door. If the water in door solenoid has failed you will have ice production but no water in door. The only remedy is to replace the inlet water valve. The are not repairable. If both water in door AND the water in door functions have ceased the most likely suspect is the door switch.
Kelly
Jul 16, 2011 | LG LSC26905TT Side by Side Refrigerator
I keep getting water INSIDE my passenger side back door!! What do I do??!!
Water inside the door is NORMAL. What needs to happen is to OPEN the drains at the base of the door. Water enters around the glass and ABSOLUTELY cannot be stopped, so, alternatively, each and every door on each and every car is designed to accept water inside the door. You may notice a plastic sheet just inside of the door panel.....This keeps the water off of the (damageable) door panel, and directs the water to the bottom of the door.
Normal condition.
May 23, 2011 | 2010 Dodge Journey
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Water has penetrated inside the door
Any water in between the glass and the door should evaporate eventually.
I wouldn't advise trying to open any seams in the door or removing the glass to get the water out as that would permanently damage your microwave.
Your models manual talks about steam/water condensation that gets trapped between the door and the glass and what to expect:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2007 | Emerson MW8107WA Microwave Oven
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
