Question about Hitachi 43FDX01B TV
STK Is there any one that knows the part # for the stk repair kit on the Hitachi 43FDX01B. I under stand that this repair kit is what i need to fix my convergence problem.
    Problem Solver:
  • 6 Answers
All the info you need is contained in this link
http://www.digitalhome.ca/forum/showthread.php?t=21847
Posted on Feb 08, 2009
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
I want to know where the STK392-110 is located in a HITACHI TV 43FDX01B. Any diagram I can see it.
there be like white meddul fin's there are black and flat with stk @@@ # on them with 2 srew's in them very ez to see
Apr 02, 2011 | Hitachi 43FDX01B TV
Looking to buy a new IC kit for my 43FDX01B, but I'm having trouble on which kit I actually need. The kit recommend here is X480293, but the kit listed that matches my TVs model number is X480296. Can...
first, I would not buy a "kit"; prices on these range from 40 to 80 dollars and most of the parts are not going to be needed.
See attached photo of convergence board in a set like yours.
You can look at the two chips in your set: either they are STK-392-110 OR -150--BOTH ARE THE SAME BUT THE 150 LASTS LONGER.
A FEW VERSIONS WILL USE STK-392-120---IT IS NOT INTERCHANGEABLE WITH THE 110 OR 150 CHIP.
In either case you can buy on EBAY (A seller I use) a pair of the chips for about 12 dollars.
About the only other thing that goes bad is there may be damaged resistors around one of the chips--usually just one but they are easy to spot and or test (see photos)
No matter how you add it up you can buy the parts you need for under 25 dollars including shipping.
If the photos and information I have provided helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 17, 2010 | Hitachi 43FDX01B TV
Screen looks like 3-d how do you fix problem?
Ur tv have a problem call convergence problems.The tv convergence board,require changing 2 STK convergencve ICS and some or all it resistors to solved the convergence problems.U know how to solders?Have soldering tools and solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 28, 2010 | Hitachi 43FDX01B TV
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
I Cannot get the red to center on the convergence adjustment.
This is a convergence output IC problem. convergence board would have to be removed -than remove and replace 2 STK IC's and check the surrounding resistors.
Sep 26, 2009 | Hitachi 43FDX01B TV
Hitachi 43GX01B 43 in. Rear
please contact the nearest repair shop.you need to be qualified to repair it!!!
Jul 31, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B convergence red line wont move
probably need to replace STK IC on convergence board and possibly associated low value resistor
May 09, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B TV Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
