Question about Tools & Hardware - Others
Bostitch M111fs I need instructions to fix air leak.
I replaced o-rings, after putting it together, I now have an air leak from cap area.
    Champion:
  • 304 Answers
You could try and contact Alfra Pnumatics, on 01707 282 700
Posted on Jan 04, 2013
2 Suggested Answers
SOURCE: looking for the bostitch m111fs flooring stapler instructions
Go to the Bostitch / Stanley website http//www.cpobostitch.com/ Browse for the product as if you are shopping ot buy it. Under the Specifications tab you can download a Schematic and/or Owners Manual in .pdf format. Quick Link to Bostitch MIIIFS owners manual: http://www.cpobostitch.com/static/manual/miiifs.pdf
Posted on Jun 04, 2009
Air leaks through cap vent
I had the exact same problem after doing a complete rebuild. If you are using the Stanley bostitch rebuild kit, check to see if you accidently swapped o-rings 6 and 63. They look the same but o-ring #6 is 1.925x.103 and o-ring #63 is 1.862x.103. Use plenty of lubricant. Hope this helps.
Apr 07, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Air leak out of driver unit
In most nail guns the piston o-ring is the problem. Inspect the o-ring for any signs of damage and in some cases the o-ring has a manufacturer defect.
Mar 23, 2012 | Stanley Bostitch SB1664FN 16 Gauge...
GOT BAD AIR LEAK WEN I PLUG IT IN.
Under the cap there are several o-rings, seals, gaskets and seats that have to be in good shape to hold air in so the nailer can work properly. If any of them are worn, broke or dried up the nailer won't function and can leak. First try tightening the cap screws. If that doesn't do it, take the cover off and check the parts inside. Stanley doesn't make repair kits for this nailer so you'll have to identify what parts need replacing and order them seperately. I recommend replacing all o-rings and any damaged seals or seats that need it. You can go to www.bostitch.com or www.ereplacementparts.com to find parts among many other aftermarket parts dealers.
Jan 20, 2011 | Stanley Bostitch PN100 Palm Nailer
When air is hooked to stapler it leaks from 2-holes by the rubber strike
If the nailer is leaking from the area you discribe, the unit needs to be overhauled as the o-rings are passing air. The kit you need is an ORK-6 O-ring kit. Any Bostitch dearler should have them.
Nov 21, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
How do i change the o rings on bostitch MIII hardwood nailer?
after you buy the o ring kit, then remove the cap screws. remove all the orings from the firing valve and cylinder, then replace cap and screws,, very important please grease the new orings before trying to put gun back together, you can get a schematic and o ring kit from toolpartsdirect.com
Nov 22, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
My framing Bostitch air gun , model N95RHN blows
prolly clogged, buy a rebuild kit and use it making sure all parts are totally clean before reassembly. in the future be sure to drain your compressor at least daily after use (more on wet or humid days) to avoid this
Nov 14, 2009 | Stanley Bostitch Coil Framing Nailer
Air leaks thru portals on cap after replacing rings and gaskets?
Remove the bumper cap and black exhaust hood from the gun. The three screws that hold the plunger to the poppet need to have lock washers and BLUE locktight on them. Clean them totally and reassemble.
Oct 03, 2009 | Stanley Bostitch STB-MIIIFS Flooring...
HOW DO I FIX AN AIR LEAK FOR A BOSTITCH MODEL N79RH?
were is the leak, all air tools need some TLC occasionally . Try putting some air tool oil in it and try it again, if this doesn't work you probably have to change a few o-ring, they break down after awhile especially if it hasn't been used in awhile .
Aug 13, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
We have a Bostitch nailer that leak out of the end
there are o rings inside the nail gun, remove the allen head screws and get replacements.
Apr 10, 2009 | Stanley Bostitch FN16250K - 2 16 - Gauge...
Looking for the bostitch m111fs flooring stapler instructions
Jan 15, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
