Question about Vizio L32 32 in. LCD HDTV
I have a vizio tv and it wont turn on it showed the vizio logo and now it wont turn on and its been like this for 2 days
  • Vizio Master
  • 8,617 Answers
The main board will need replacement. Its very common issue where the set will freeze at the vizio kogo then eventually it wont turn the logo from orange to white so it can power up. Replacing the main board should solve the issue. You can get the replacement main board from www.tvcircuitboards.com
Posted on Jan 03, 2013
SOURCE: my e420vo vizio wont turn
Did you ever find out what was wrong? This happened to me just now!
Posted on Apr 19, 2011
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
  • 13 Answers
SOURCE: when i turn the tv on shows the vizio logo only
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
djchillsnyc
  • 152 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
  • 133 Answers
SOURCE: Hey there, I have a 6 month old vizio 32" LCD 60hz
Most probably the mainboard of the TV has a problem. But no worries as it is only 6 months old call up Vizio and they'll replace it for you free of charge :)
Posted on Mar 27, 2011
Vizio m420nv tv wont turn on but logo lights up
Test the PWR-ON terminal on the power supply and see if you have about 3.5 volts there
May 03, 2018 | Vizio Televison & Video
I have a vizio tv...i can see the vizio logo light up but wont turn on...
Corrupted firmware. A firmware update is necessary. Contact any service technician.
Nov 21, 2015 | Vizio VO Televison & Video
My Vizio E422va turns on but wont go past the start screen with the Vizio logo. The remote won't work either. It's like it freezes at start up.
Corrupted firmware. A firmware update is necessary. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 10, 2015 | Vizio E422VL 42 in. LCD HDTV
Vizio VO47L FHDTV10A wont turn on, logo goes from amber to white, tv clicks once and wont turn on. remote will try to turn the tv on. suggestions?
check your inverter board and wires 2 make shure there not arking. then check your six transformers on your inverter with volt meter
Jan 31, 2013 | Televison & Video
Tv wont turn on fuse is good
does the vizio logo light up orange ? If so and it doesnt turn white then the main board would be suspect. If the logo doesnt turn orange when its pluuged in then its the power board. You can get either board from www.tvrepairworld.com
Aug 12, 2012 | Vizio VO47L 47 in. LCD TV
Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Nov 22, 2011 | Vizio E550VL 55 in. LCD HDTV
Jun 25, 2009 | Vizio VO47L 47 in. LCD TV
Vizio L32 32 in. LCD HDTV Logo
446 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
