Question about Sanyo Televison & Video
Lines on my tv.
It wasnt working at all i put in a power supply now it comes on but has lines
  • billy channell Jan 03, 2013
    if you keep turning it on and off the picture stays on the lines go away
  • Sonny Berry
    Sonny Berry Jan 04, 2013
    Its more than likely a connection issue on the LVDS cable to the Tcon or the TCons two ribbon wire connections
  • Sanyo Master
  • 8,617 Answers
Can you describe the type of lines or possibly post a picture? That would assist in offering a possible solution to the cause. Please respond to this same post for further assistance.
Posted on Jan 03, 2013
Sansui hdlcd2600a no picture
If it's a LCD tv I would check the power supply board. Sometimes capacitors may look good but still test bad.
Aug 31, 2012 | Televison & Video
Mitsubishi 73733 DLP Completely Dead, No Power, No Lights
Hi we had the same problem after a storm, the tv shut off - no sounds no lights - had a tech come out to check the tv and he told me that the main/motherboard had been struck by lighting (I figured that part), so that gave me a starting point...he wanted to charge over $600. Soooo I searched and found the part on ebay and ordered it thru tvbservice it cost us $200 and we put it in ourself. (p/n 934C260002) It wasnt hard to do at all, just alot of screws lol. The end result was that...THE TUBE IS BACK UP AND RUNNING!!!! Hope this helps!
Jul 30, 2012 | Mitsubishi WD-73733 73" HDTV
HITACHI PROJECTION TV HAS WAVEY LINES ON IT THEN SCREAN GOES BLACK
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 23, 2012 | Hitachi Televison & Video
The remote control wasnt working earlier on. i switched off the TV set, and now i cant turn it on. there is no red light
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD...
No power getting to TV.
I have a 32'' Sova LCD tv with the same problem. The problem maybe your power supply. In my case, it was the power supply (no.# YHi 090-02180-13) it had no voltage out put, no blue light and no working fan. Remove the power supply and take it to your local repair center and check it for voltage out put. I found it difficult to locate the same power supply after the decision not to repair mine. There is an alternative I found on ebay, it doesn't look the same, but all the spec checks out. I had this power supply for two days and my tv work great so far so good.
Jan 05, 2009 | Sova DSV32P112 32 in. LCD Television
LG 47" LCD FLAT SCREEN
IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE.
Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture. When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
Jun 05, 2008 | LG 47LC7DF 47 in. LCD HDTV
Daewoo cp185
Power supply may be faulty.
Initially check fuse in power line input.may be burned.
Jan 23, 2008 | Televison & Video
Will Not Turn On
hi,
iandojay
check PW suppy is ok check all voltages in the micro controller IC
Dec 05, 2007 | Televison & Video
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Televison & Video Logo
20 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
