Question about Fellowes Powershred SB-99Ci Heavy-Duty Cross-Cut Shredder, 17 Sheet Capacity
Fellowes shredder sb 99ci no power
Just stopped working, it is not jammed. I have power going to the door shut off as this is the only light that comes on, and goes off when door is engaged in closed position. Seems to have lost power somewhere as all other control lights remain out. Are any of the switch contacts more problematic to failure. I have an autistic son who loves to shred and press all the buttons.
FixinFax
  • 3085 Answers
SOURCE: My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Posted on Nov 20, 2009
fellowesrep
  • 102 Answers
SOURCE: shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
  • 105 Answers
SOURCE: The "bin full" indicator is always on.
you will have to clean or replace the bin full sensors
Posted on May 14, 2009
  • 250 Answers
SOURCE: shredder will shred about 3/4 of a sheet of paper
If your shredder has a feature where it won't run with the door open/shredder off the bin, you probably need to make sure that the safety is engaging properly. If the motor seems to sound very labored when it runs, unplug it, and check the blades to make sure there's not a lot of extra stuck in them. You may need to clean them and lubricate it with special shredder oil ONLY.
Posted on Nov 25, 2009
Chamberlain garage door opener, it goes up but won't come down, it stops various places and goes back up. We have reprogramed does not help. This is brand new, please help
It sounds like it is getting jammed. Check and make sure the door can slide up and down freely otherwise, the motor will reverse and lift the door again. You may have to do a reset on the motor drive itself to clear the programmed open / shut distances. There should be a release arm to allow you to open and shut the door without the motor being operated so you can check for binding / jamming etc.
Mar 21, 2017 | Building Materials
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Interior roof lights won't go off
This can be caused by a door or trunk being ajar, be sure you shut all doors firmly, if there is still no resolve check by shutting all doors then open one up and press the button (if any) on the inside of the door jam and see if it is broken or the light goes off.
Jun 04, 2012 | 2007 Audi A4 Avant
My parents bought a Haier HBF655TEME washing machine last year december. Last week it stopped working. The door light stays on continuously when clothes are put in and the door is shut and it doesn't...
It is possible that the door switch has failed as the bulb is ON even when the door is shut . This indicates that the SWITCH is not cutt off and so the program controller will not allow the module to go forward or work. It is needed that you start from this point to use a multimeter to check the switch/ poles contact to confirm.
Jul 01, 2011 | Washing Machines
2005 Honda Accord, all three passenger power windows stopped working. The drivers window works and the window lock is not on. When I try the switch on each of the passenger windows i cvan hear a clicking...
you most likely have a power/ground/switch issue in the drivers door. the power for the other three doors must first travel through the switches in the driver door before it goes to the passengers. hence the reason why when somebody rolls down a passenger window and you push the up button on the driver door the window stops moving. the wires can break inside the rubber boot in the door jam. you can also have an internal problem with the driver door switch unit. you would need a wiring diagram to diagnose this concern.
Mar 23, 2010 | 2005 Honda Accord
Door ajar light - power windows and alarm
you may have a broke wire in the door harness
Jul 16, 2009 | 2002 Ford Explorer
Power shuts down when I try to close or open
Your motor may be working too hard anad ripping the reset button on the garage door,
Try increasing the power on the unit ( should be some type of dial.) or the door may be jamming up somewhere, Try disconnecting the opener from the door and see if it goes up easily, the door might need service
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old 139.53985dm garage door opener shuts off going down
Unplug unit at power source and check and tighten all connections in the control box. And try this link.
http://www.garagedooropeners.us/technical_information.html
Mike
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Paper Jam light will not go out
Please ensure that the paper ways are really clear and the doors and other deivces are truly shut Then investigate if this particular printer has a reset mode. It might not be a specififc button - but perhpas prerssing a sequest of buuton with the machine off then holding those button down switch the machine on. Some answer may also be on www.fixyourownprinter,com
May 22, 2007 | Lexmark E232 Laser Printer
Fellowes Powershred SB-99Ci Heavy-Duty Cross-Cut Shredder, 17 Sheet Capacity Logo
1,965 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
