Question about Apple iPhone 4S
My iPhone is getting slow
How do I speed up my iPhone? It used to be much faster but now it's slow.
    New Friend:
  • 46 Answers
Try closing all the open apps. Double click on the home button and long press (press for about 3 or 4 seconds) an app on the bottom tray. Tap on the red X and close each app. Don't worry, it's not deleting the apps, just closing them from the background. Try closing them all and see if that speeds things up. Good luck!
Posted on Jan 03, 2013
Phone is damn slow
If it's a android I recommend deleting apps you don't need and going into the Settings and into the Apps tab. Tap on any app such as Facebook or something of the sort and tap clear cache, do that for several apps to free up memory.
Aug 17, 2016 | Cell Phones
How can I make my iphone go faster?
You can try these tips & tricks to speed up your iPhone.
  • Delete large apps that take up a lot of space
  • Get rid of old photos videos and music
  • Remove old text message
  • Empty Safari's cache
  • Close all the background apps
  • Turn off auto app updates
  • Turn off automatic downloads
  • Disable Location Services
  • Restart your iPhone every once in a while
  • Reset your device completely
And a complete cleaning for your iPhone is also needed, PhoneClean is such a professional cleaner made to remove junk files from your iPhone to make it run faster. How to Make Your iPhone Run Faster
May 28, 2015 | Apple iPhone Cell Phones
Hoe to improve iphone 3g processing speed... it is so lazy and waste my time too
You cant increase the 3g processing speed if your iphone is stock.
Its possible to increase it if your iphone is jailbroken.
Right now the 3g has a processor speed of 412mhz which is pretty slow on todays standards. Most phones now are 1ghz to 1.8ghz.
Even if you jailbroke the phone. The maximum that u could increase the processor speed is to 550mhz. Downside is that when you increase the processor speed past its stock mhz, the battery will die faster.
Aug 08, 2013 | Cell Phones
Why is my iPhone 5 so slow?
That app is likely only testing the network speed of your iPhone, and if you're using a cellular connection instead of WiFi, the results will depend heavily on which provider you're with and they're coverage in your area.
If you're using the same WiFi on all your devices, the iPhone 5 should not be slower than other iPhones, there are multiple reasons as to why it is getting slower speeds however.
If you're running the tests at the same time, they may interfere with each other so run them one after the other.
If you're already doing that, your router may be prioritising the other devices over your iPhone 5, assuming other devices are using the internet at the same time.
Dec 02, 2012 | Dual Electronics CECT P168 Cellular Phone
Wire feed speed problem
Check the speed control board's voltage from the fan. If you are below 20 volts, 1- oil the cooling fan bushings to see if that helps. Otherwise adding in a discrete 24 volt 1 ro 1.5 Amp "control" transformer and a 2 ohm 50 Watt resistor in place of the fan's 24 volt tap (it rarely gets to 24 volts) should bring your speed up.
This does assume the board is fully functional.
Dec 27, 2011 | Welding Tools
I want to repair my phone
try formatting your phone. it'll be faster after that
Nov 26, 2011 | Nokia E63 Cell Phone
My iphone is slow and it takes a long time to connect calls
Sounds like your Iphone Software is Corrupted go to the Iphone website and look on how to factory reset the phone this will re-install the phone to how it used to be and making it connect calls faster, Please be aware if you do this you will loose all contacts and data back it up before you start this. factory reset you will need the data transfer cable that came with the phone and a computer along with the Iphone or Itunes software installed.
Jun 27, 2011 | Computers & Internet
For my trip to Indonesia for a month I thought of buying two Sanddisk SDHC 8GB Exreme Pro UHS-1 cards. I have a Panasonic LX2 camera, what is the max memorycard speed (class) the camera can take? Is...
The camera can use any speed card. If you get a very slow card, the camera will slow down to it's speed. On the other hand, if you get a very fast card, the card will simply slow down to the camera's speed.
Faster cards tend to cost more than slower cards. For a camera like this, I wouldn't spend more money than for class 4 cards. Faster cards will not make the camera operate any faster.
Jun 08, 2011 | Cameras
Apple iPhone 4S Logo
114 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
