Question about LG Televison & Video
My lg42lg30 tv wont turn off and the meno icons are going crazy cannot control it
I cannot watch cable or a dvd because the meno icons are going crazy on my screen they wont stop blinking all over the place
  • LG Master
  • 8,617 Answers
Sounds like you have a main board issue. But if you can post a picture that would help confirm if it is the main Board. please respond to this same post for assistance.
Posted on Jan 03, 2013
  • luis rasteiro Jan 03, 2013
    hello again what would you like for me to take a picture off
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 8 Answers
SOURCE: Channels change by themselves after 20-30 minutes of tv being on
Have you tried covering the IR eye on the front of the TV when this starts occuring? Sometimes other devices in your home can emit infrared light that in rare cases can be picked up by your TV as a command from the remote. If covering the eye seems to stop the problem, I would say my guess is correct. If the problem continues even with the IR eye blocked I would say that the internal tuner of the TV might be defective. good luck!
Posted on Jun 17, 2008
ensapp
  • 30 Answers
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
Bad caps in the power supply. Replace all bad cap or replace Power Supply Module. If you choose to try and fix it yourself yourself will need a ESR Meter to check the caps in circuit. Let me know if this helps.
Posted on Oct 16, 2008
  • 187 Answers
SOURCE: lg42lg30 no picture
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
Distorted picture and color problems
If when you watch tv it is fine then your problem is not with the tv. First eliminate the possibilities. plug your DVD into another tv and see if the problem persists. If it does it is your DVD. Next, replace cables. Not likely but the jack on the tv could be bad. Check those things and let me know if you have any other questions. There is more that can be checked before getting crazy.
Jan 11, 2014 | Sanyo HT27546 TV
Codigo de dvd pronext remoto
Trata con el c?digo del DVD marca 3M, ese es compatible con el DVD marca pronext, por lo menos para las funciones b?sicas.
Aqu? detallan como lo usaron desde una app de smartphone:
http://tv.yoreparo.com/dvd/codigo-de-dvd-pronext-t626432.html
Saludos
Aug 30, 2013 | RCA Universal Remote Control
How to install with time warner cable box
If your tv has auxilary RCA audio and video inputs on it (red, white, yellow), you can go directly from the dvd player into the TV. Choose the corresponding input (video 1, aux 1,2 or similar) on the TV to watch dvd, possibly controlled by the TV remote. Therefore it doesn't run inline with the cable box via a 75ohm cable.
Apr 15, 2010 | Philips Magnavox DVD/VCR Dual Player
No signal from samsung dvd-vr375 and tv
That means the dvd (I assume you meant dvd not vcr) needs tuning to the stations. Press menu, then select the tool box icon(or setup) and select the tuning option. Select auto tune and press go(centre button).
Give it a few minutes to tune in and away you go.
Jan 02, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Problem with Surround Sound when watching TV
No wonder you havent gotten no reply your listed under wrong tv
May 06, 2008 | RCA D52W19 52" Rear Projection Television
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Need codes for the RC450 remote
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 13, 2007 | RCA RCR450 Remote Control
Disk won't load
I would verify that connections between the DVD player and the TV; then go into your DVD’s control panel and re-set to original factory settings. I would also make sure that your TV’s settings are set to the correct connection settings as well.
It would also be nice if you included the make, and model of the DVD player and which connections are you using to connect to the TV.
Nov 10, 2007 | Televison & Video
Televison & Video Logo
91 people viewed this question
Computer Repairing
Computer Repairing
