Question about Dell Latitude E6410 Notebook
My dell latitude E6410 will not turn on
I press the power button stay on for 3 sec and turn right off the only light that i get is the power button and the caps lock button
zzedly
  • 300 Answers
SOURCE: Dell Latitude C510/610 wont turn on
I have more of a suspicion of the CPU fan than the hard drive, right now. If a hard drive goes bad, the system will wake up, go through it's POST (Power On Self Test), and then tell you there's an issue with the hard drive. If the CPU fan goes bad, the system turns on, sees an RPM of 0 on the fan, then turns back off. That hypothesis also fits in with the slowness you were seeing. If a CPU starts to overheat (because the fan isn't running well), it will start to throttle the clock speed down in an attempt to produce less heat.
Unfortunately, it sounds like your laptop may be in need of a professional repair facility.
Posted on Mar 07, 2008
SOURCE: Dell Latitude C610 Laptop won't turn on
i've been bummed with this laptop.
same thing happens to me - except all my lights come on for a split second then only the power light stays on underneath the monitor - which is black - and nothing else shows any sign of being turned on.
also..
the f, z, n, and some other key are broken.
well - they work, but only after several hard hits.
Posted on Nov 08, 2008
  • 285 Answers
SOURCE: dell latitude d820. press power button. no
This may be a really stupid question, but you could have overlooked it... Are you sure the power cable is attached to the laptop correctly? It seems like it's just short of power.
Posted on Jun 07, 2009
  • 97 Answers
SOURCE: dell precision m60 press the power button the
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Posted on Feb 23, 2010
2coolrick
  • 560 Answers
SOURCE: dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
Posted on May 13, 2010
Testimonial: "Excellent purchased the new adapter and and what do you know problem solved.Thanks a million."
My dell latitude e6410 won't turn on When I press the power button it stays on for 3 sec them turns back off the battery charge light is on when plugged up Need help please
This usually indicates an overheating problem. Try cleaning out the fan with a can of compressed air, if that doesn't work you will need to bring it to a technician who can test the motherboard as the graphics processor may need to have solder reballing done.
Dec 29, 2013 | Computers & Internet
Wireless switch working
Press Fn and F12 togetheror Fn and the Fkey that has the aerial symbol on.
Oct 26, 2013 | Dell Latitude E6410 Laptop
Dell Latitude E6410 does not connect to wireless printer
connect it by cable to your pc first to install it then remove the cable
Feb 11, 2012 | Dell Latitude E6410 Laptop
How do i turn on the keyboard back lighting?
Hold down Fn and hit the right arrow button.
Aug 15, 2011 | Dell Latitude E6410 Laptop
Hi. My Dell Latitude E6410 does not recognize a Epson Projector, model EMP-7800. How can I solve the problem?
Hi
you must tell the laptop to display out on the projector,
how to do that?! you must toggle the display path
Generally, there is button ( with Fn keys ) have dusplay screen sample on it, use it with Fn to toggle the display
Display have 3 modes:
  1. laptop screen
  2. outside LCD projector or monitor,
  3. or bith 1 + 2
you can press the keys 3 times ( at maximum ) to have the display on both laptop screen and projector
Good Luck
May 13, 2011 | Dell Latitude E6410 Laptop
3 Lights on display panel Dell D505
YOU HAVE A FAULTY BIOS.I HAD THE SAME PROBLEM WITH MY DELL INSPIRON 5150.REFLASHING THE BIOS SOLVED THE PROBLEM.GOOD LUCK.
Sep 11, 2009 | Dell Latitude D600 Notebook
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Dell Latitude E6410 Notebook Logo
1,736 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
