Locked oven
SOURCE: Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
SOURCE: need owners manual for Caloric prestige series
prestige cooker with built in oven is suddenly making loud noise .don't know what to do?
SOURCE: how to light the pilot
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: After searching the web i've realised i need to
http://www.reliableparts.com/ Will ship anywhere in the US. You can either find it on there website or call them if your model number doesnt show up. Now to replace this, first turn the power to the oven off at the breaker or by unplugging it, then you just need to access the igniter by removing the bottom plate in the oven. Then remove the 2 scews holding the igniter on, clip the wires so that they are as long as possible, strip the old wires and the new igniter wires, the new igniter SHOULD come with porcelin wire nuts. Tie the wires together using wire nuts provided. Re-install new igniter and restore power to unit to test.
SOURCE: I have a caloric oven,
I have a caloric prestige wall oven and it was working fine,now it has no power the lite won't come on.The oven is about 15 17 yrs old maybe so what can I do to fix it,it's a real good cooker.
