Question about Gateway DX4300-03 Desktop PC
Installed power supply and recived : Reboot and Select proper Boot device
Computer was dead for about 1 month. I just installed a new power supply and it started well then got stuck on Boot device message.
  • Gateway Master
  • 27,725 Answers
A couple things to check first, make sure there's no floppy disc/cd in the drives, and if you are comfortable with computers, you can enter the boot setup of your BIOS, and check to see that your hard drive is listed as the primary boot device.
Restart your computer during the boot process you will see on the screen a certain key to press usually the Delete or F2 Key to enter set up this will vary depending on your computers bios.
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to advanced bios features press ENTER to check if its set to boot from your hard drive. The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? If for any reason you have changed a setting in bios and you are unsure of it you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart .
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Or there is a connection problem such as a bad cable
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ribbon ide this will be the first to fail. Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error Hope this helps.
Posted on Jan 03, 2013
5 Suggested Answers
  • 11800 Answers
SOURCE: When I turn the computer on, I get the following
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Posted on Nov 26, 2010
Testimonial: "Thanks- I chated with Gateway and NO help. Not even what to try."
sodeep
  • 3267 Answers
SOURCE: GETTING ERROR: REBOOT AND SELECT PROPER BOOT
its not detecting your HDD. on boot enter BIOS & check whether your HDD is being detected by the MB. IF not(most possible) then check the power & data cables to your HDD, Check your SMPS too, if SMPS OK then your HDD is corrupted. GET new HDD
Posted on Jan 01, 2011
krbshg
  • 430 Answers
SOURCE: at the startup menu i am getting a message that says, Reboot and Select Proper Boot Device or Insert Boot Media in selected Boot device."
Firt thing you can check is wthr your harddrive is detected or not. to do that you have to enter to the BIOS,To Enter BIOS you have to press DELET or F1 or F2 key(Mostly DELET). Now inside the BIOS in main menu check if your hard drive is showing or not. If it is showing there then you try to find out boot sequence, option after getting the boot sequence optuon check if the first device is other then hard drive.
if your harddrive is detected and your first boot device is also set to HARD drive then it might that your Operating system is Crash, in that case you need to re install the OS.
Now if you can see your hardrive in your BIOS then you can open the case( remember to unplug all the cable, Power, VGA, KEYboar ...etc) and try to inter change the harddrive cable connting cable, i mean just try to chage the port of the cable to other one and try switch on your computer ... if still you find the same problem then try changing new cable. ....well if still you have the same problem then i am afraid that you might need to replace the hard drive with new one.
Sorry for the Bad Englsih. Hope the above steps will work for you and you understood what i tried to say.
Cheers:)
Posted on Jul 25, 2012
  • 4961 Answers
SOURCE: reboot and select proper boot device or insert boot media in selected boot device and press a key w7
Give this a try you probably have a mbr virus..
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Posted on Sep 06, 2012
My computer says reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key
Hello
This means that your hard drive is not detected by your computer.Unplug your computer then open the cover then check if the connector of the hard disk are properly connected and the power supply on the hard disk are also properly connected. And try to feel if your hard is vibrating when you powered it on. Because if the hard disk does not vibrating it means that your hard disk have no power or not properly connected to the connectors or damage. Sometimes i experienced this problem thats all i done then it works.
Jul 29, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
Tip
Fatal issue: Reboot and Select proper Boot device
<p><b>Issue:</b><br /> <p>Reboot and Select proper Boot device <br />or Insert Boot Media in selected Boot device<br /> <p> <br /> <p> <br /> <img src="matrix12_2.jpg" /> <br /> <p><b>Cause:</b><br /> <p>The boot record could not find a bootable partition so control was passed back to the BIOS. This issue occurs prior to the start of any Windows code. <br /> <p>It can be caused by a power-failure while the disk is in the middle of writing, a virus damaged the entry, a failing disk drive or a serious software bug damaged the partition entry (although Windows typically protects against this). This issue cannot be easily caused by any action you performed, unless you turned off the power without going through Windows shutdown.<br /> <p><b>Workaround:</b><br /> <p>1. If you had changed, added or removed hard drives, or changed or removed drive cabling, likely something is wrong. Recheck that the drives are properly installed and the cabling has not changed. Switching cables to different motherboard connectors or changing the master/slave drive jumpers (on old ATA drives) can cause this problem. In some systems, the cables were not plugged into the drive or motherboard securely and may have worked loose. Reseat all drive connectors.<br /> <p>2. It's also possible a hard drive is failing. Use a system diagnostic to validate the drive or swap to another hard disk.<br /> <p>3. If the first bootable drive is missing (disconnected or dead) the BIOS may be attempting to boot from a second disk. Confirm the primary drive is working.<br /><br /> <p> <br /> <p>Hope this will help...Your response is very much appreciated...<br />
on Jan 24, 2011 | Computers & Internet
Screen shows "Reboot and select
what you want do is disconnect your hard drive then disconnect the power from your motherboard the from the power supply, and press the power button the connect all the power cables back then enter bios screen go to the boot tab and select boot device priority and move your hard drive up.
May 21, 2011 | Computers & Internet
I have put new hard drive in - When booted up it says - Reboot and select proper boot device or insert boot media in selected boot device and press a key.
there can be two scenarios
1. the harddrive is not installed properly
2. the harddrive is not selected as the first boot device in the BIOS of the computer.
After you install new harddrive, you will have to reinstall the Operating System in the computer as well.
For further assistance, log on to HNetworking.com and use Online chat option
Admin
HNetworking.com
Feb 03, 2011 | Computers & Internet
Replaced hard drive and am getting a "Reboot and
Hi seqhdha,
The reason why you're receiving that meesage is the system is not detecting any bootable device on the computer or it is boot from a media that is not bootable (CD/DVD/USB). To fix this problem if you already installed the Operating System you can change boot priority setting and select the Hard Drive as the First Boot Device however, if you havent install the Operating System you need to select the CDROM as the First Boot Device and insert the Windows Installer.
Here are the steps on how to access the BIOS Page.
1. Restart the computer and while it is booting tap DELETE button.
2. On the Bios page look for the BOOT tab then set the priority to either Hard Disk or CDROM depends if you already installed the OS or not.
3. Follow the instruction on how to install the Operating System
4. Rate me if this helps so i can help others.
Thanls for using Fixya.
Jan 31, 2011 | Gateway 550GR PC Desktop
I purchased a used vaio vgc-rb43. Upon turning on a message appears stating "reboot and select proper boot device or insert boot media in selected boot device" What can I do from here?
It probably is a "dead" disk-drive inside the computer.
So, the computer would try to boot from the 3.5-inch diskette drive, or the CD/DVD drive,
if there was "bootable" media inside the device.
So, you need to take the computer to a computer-store, to remove the "dead" disk-drive,
and for them to sell you a "new" and "compatible" disk-drive.
Then, you must re-install Windows (did the seller include a set of "System Restore") CD/DVD disks? Or, can you telephone Sony, and order a replacement set of those disks?
Oct 10, 2010 | Sony VAIO (PCWA-A200)
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
Compu is averatec d1002uhce-1 2 month new .... i
sounds like either you have a disk in the cd drive and it won't boot because of it or you have some other device that it is looking to boot from instead of the hard drive.... if not, then you have a bad hard drive. I would first unplug all accessories and eject any discs... Next go into the bios (if your comfortable with it) and make sure the hard drive is in the boot priority... if nothing, then take the cover off and disconnect and reconnect your hard drive. If that doesn't work then you probably have a faulty drive.
Mar 23, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
New hard drive was installed and will not boot
plz check if your hard drive is detecting,if yes then try to reinstall the OS otherwise your hdd is dead and replace it.
Apr 22, 2008 | Seagate Barracuda 7200.9 500 GB ATA-100...
Gateway DX4300-03 Desktop PC  Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
