Question about HP Hewlett Packard Pavilion A6200N PC Desktop
CD/dvd drivers missing or malfunctioning
When ever I open my Itunes I get this message. "The registry settings used by the itunes drivers for importing and burning CDs and DVDs are missing. This can happen as a result of installing other CD burning software. Please reinstall itunes."I've tried reinstalling itunes and I get the same message. itunes does open and I can get to my library but I can't use my burner. Can anyone help me please? I have the same problem. One day, my Windows drivers stopped working, so I ran through the options on the Microsoft help site to fix the problem. My problem was solved, but it caused this same problem with iTunes, as the Microsoft support site said.
  • Anonymous Jan 19, 2009
    I'm having the same problem with Vista... it worked fine for a week or two, now won't work.. i can download music to my computer off a CD but not to Itunes
    Problem Solver:
  • 9 Answers
Sounds like you have and Upper and Lower Filter issue in the registry.
Listed below is the link for the MS document on how to fix this: http://support.microsoft.com/kb/929461
IMPORTANT
I suspect you did not complete all the steps in the document. In the document you need to delete the upper and lower filters in the registry and DELETE the burning software you added, shut down and then reinstall the software. This is often difficult for users since they have no idea what app is causing the problem.
With iTunes, make sure you are using the latest version. Older versions caused this upper and lower filter issue among other burning apps.
In some extreme cases you must uninstall and reinstall ALL burning software on your PC. This is easy on an HP. Delete the SW from Programs and then use Recovery Manager C:\PC Help and Tools\ etc..,. to run Application Recovery. You can only install one app at a time. Shut down between each install and check if your drives show up in Device Manager and burn.
Following the process above (installing one app at a time) will allow you to find out which app you added is causing the problem.
All the HP apps on the PC work fine as the PC is tested for issues like this. Something was added that over-wrote the Upper and Lower filters, essentially corrupting them so your ODDs don't work or don't even show up in Device Manager.
Good luck
Apex44
Posted on Mar 04, 2009
Every time I start itunes I get a message that the registry settings used by itunes fro importing and writing CD/DVDs are missing and to reinstall itunes which I have done at least 20 times but with no...
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running.
2. Click Start, type regedit, then press Enter.
3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
4; Its better you clean/repair Windows registry with RegInOut.
4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry.
5. Start iTunes. The offending message should be gone!
Jan 08, 2011 | Apple iTunes
Every time I open Itunes, a dialog box opens and tells me that a registry setting is not allowing me to use the CD/DVD burner. I have reinstalled Itunes but that hasn't solved the problem. I am able to rip...
Make sure iTunes isn't running. 2. Click Start, type regedit, then press Enter. 3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers 4; Its better you clean/repair Windows registry with RegInOut. 4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Sep 29, 2010 | Apple iTunes
Itunes drivers for importing and burning CDs/DVDs missing where can i get them? Bill
It seems that some users installing iTunes 8 on Windows systems are encountering an error message:
“ERROR: The registry settings used by the iTunes drivers for importing and burning cds and dvds are missing… Please re-install iTunes”
iTunes uses GEAR software drivers for importing and burning CD’s & DVD’s. Re-installing (or installing the latest GEAR drivers seems to fix this problem. No reboot required for this install.
You can get the current GEAR drivers here: http://www.gearsoftware.com/support/drivers.cfm
If this does not fix your problem download a fresh installer for iTunes here: http://www.apple.com/itunes/download/
Uninstall iTunes, reboot, & then do a fresh install of iTunes.
Hope This Help You
Oct 26, 2009 | Apple iTunes
Itunes
reinstall the product.
Jul 16, 2009 | Apple iTunes
Cd/dvd won't play, fix that with a registry fix
goto majorgeeks.com and look at other registry fix programs , like registry restore
Jul 09, 2009 | Acer Aspire 5920 AS5920 Notebook
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jun 24, 2009 | Apple iTunes
ITunes registry error/CD-DVD not being recognized
I had the same problem with iTunes and installing the GEAR driver fixed it. If the drive itself is disappearing then the problem is probably more than iTunes. Try updating the actual CD driver at the Dell Support Page then install the GEAR driver again.
Feb 14, 2009 | Apple iTunes
This fix is from:
http://getsatisfaction.com/apple/topics/registry_settings_missing
K replied on April 14, 2009 00:27 // Good news!!!!I have had the same problem as you and have been dealing with it the last 2 days-uninstalling itunes,quicktime and then reinstalling and installing gearproduct download??Anyway to make a long story SHORT:
1. Do a search for a file -GEARAspiWDM.inf in C drive
2. Right click and install
3. Reboot the computer
4. itunes should be working without the error-I hope, it worked for me!!!!!!
good luck, K
Jan 28, 2009 | Apple iTunes
ITunes not able to burn CD's
you already have other cd / dvd burner software on pc / laptop...use it...(can i suggest a better software than itunes for burning..unless you have this already..nero, ashampoo and / or burn4free cd / dvd)...nero has much more to place on the menu of dvd...cd (u can get creative)....this way your new version of itunes will just keep your ipod up to date (no more regs problems)
Jan 04, 2009 | Toshiba Satellite A105 Notebook
Try uninstalling itunes, restart computer, and then reintall itunes.
Dec 24, 2008 | Toshiba Satellite A105 Notebook
HP Hewlett Packard Pavilion A6200N  PC Desktop Logo
398 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
