Question about Bosch Washing Machines
Bosch wkm41 motor not working
No spin
3 Suggested Answers
SOURCE: bosch maxx clasic front loader Wkm41 the control
I had the same issue this morning. I turned on the washing machine change a few settings, but didn't want these setting so i turned off and on again. When i turned it back on the panel was blank, but what had happen was the spin button was stuck in. Once i free the button the panel came back on.
Regards
Posted on Feb 05, 2011
  • 6277 Answers
SOURCE: I have a Bosch maxx
I suspect that there is water still left inside as the drain pump has been unable to complete its task so they are being spun in water!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 19, 2011
Need a manual for bosch front loader wkm41
http://laundry.manualsonline.com/manuals/mfg/bosch/800_series.html . That should be the manual for the bosch wkm41. If not get back to me and i'll take another look. Also the bosch website has manuals searched by serial number if you get too stuck.
Dec 28, 2014 | Bosch Washing Machines
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
I have a Bosch maxx classic front loader washing machine type wkm41 that won't spin, the clothes arent being washed and come out sopping wet?
John C
Sep 19, 2011 | Bosch Washing Machines
Bosch maxx clasic front loader Wkm41 the control panel has just died. what can I do to fix this?
Regards
Sep 10, 2010 | Bosch Washing Machines
Spin cycle does not operate
Your clutch on your motor is not working. Your clutch on your motor controls how the motor either spins or agitate.
Dec 15, 2009 | Bosch Washing Machines
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFO2060 not spinning at spin cycle.
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jul 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch 2460 won't spin
only brushes in motor ,he taking the mikey motor only 236.00 from bosch
Jun 30, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
