Question about AudioBahn A2300HCT Car Audio Amplifier
Why is my audiobahn a2300hct in protect mode
The amp was working. and then i messed with the gain a little bit and it stoped working the fans are on and all the leds are on. just no music. honestly this amp is easy to take apart and work with so if its internal tell me how to fix it. i dont beleive its clipping. and the amp shows no signs of fire or anything getting hot.
SOURCE: Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Posted on Aug 19, 2007
  • 631 Answers
SOURCE: Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Apr 05, 2008
wesmckay
  • 9 Answers
SOURCE: Protection Light On
If the speakers are still fine, then I'd say it blew the transistors in the amp.
Posted on Jan 15, 2009
  • 506 Answers
SOURCE: audiobahn a8002t amplifier in protection mode
Let's measure some voltages. If you have a DMM measure the DC voltage at your amps power supply input. If much less than 10 volts I would suspect you may have possibly damage your power wire. When you have a lot of current flowing through a wire the resistance will change and cause a larger voltage to drop across that wire. Having to low of an input voltage is a trigger mode for some amplifiers to go into protection. Let me know what you find and we can go from there.
Posted on Dec 22, 2009
  • 155 Answers
SOURCE: Heeey. I have the Audiobahn A2300HCT and it has a
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
Posted on May 16, 2010
My amp rca wirers in the inside of the amp burned up what should i do?
u can replace them with a little bit of sawder
it takes some itime but its poss
ible
Jun 21, 2011 | AudioBahn A2300HCT Car Audio Amplifier
What does it mean when my green lights on top go up to red
it is in protect mode. check the ground first and make sure it n bare metal on the frame. then check the ohm load s the subs make sure its safe for the amp. then try backing the gains down a little bit, electronics dont do well when they get hot
Sep 15, 2010 | AudioBahn A12001DQ Car Audio Amplifier
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Heeey. I have the Audiobahn A2300HCT and it has a very strange problem. When i start the amp its in the normal blue mode but i have no sound. The one power output (LEFT) indicator shows +3DB (full) the...
Apr 08, 2010 | AudioBahn A2300HCT Car Audio Amplifier
My audiobahn amplifier isnt working, the status
it maybe fixable. the problem is that when you find what is burnt or messed up, you replace it. after that you need to find out why it burnt or messed up. i wouldnt recomend trying to fix it your self unless you wanna chance it. but if you take it to a technician that can fix it the will be able to tell you if it can be repaired. also check your power and ground wires. make sure youre getting 12 volts to the amp. check your subs and make sure they are good. a bad sub will put a amp into protect. good luck.
Dec 17, 2009 | AudioBahn A2300HCT Car Audio Amplifier
I HAVE A A2300HCT AUDIOBAHN I WANT TO CONECTED TO 6 12 INCH CROSSFIRE ALL 6 GIVE ME 1 OHM DO YOU THINK I CUOLD LOWER THE AMP TO 1 OHM IF NOT WHATS MY BEST CHOICE
Hello VICENTEMULGA,
According to Audiobahn's specifications, the amp is stable at 1ohm, either with the channels driven separately or in bridged mode. With the channels driven separately, the rated output is 1,200 watts at 1 ohm. In bridged mode, the rated output is 2,400 watts.
You'll need an absolute minimum of 2gauge power and ground, and preferably 1/0gauge and a really good alternator to provide enough current for the beast.
Hope this helps.
May 05, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
How to fix clipping
turn down your gain levels. is the protection turning on? also make sure u aren't bridging.
Apr 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A2300HCT Car Audio Amplifier Logo
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
