Question about Kyocera Finecam S4 Digital Camera
Camera will not stay on!
My camera turns on, the lens open up but them immediately retract and the camera switches off. The battery has full power. I took the casing off but nothing was apparent, so I put it back together.
    Genius:
  • 2,985 Answers
Kyocera online Technical Support team- should sort this for you - it is I thing a switch fault and the camera should be replaced- if it is out of warranty a nominal fee will be charged.
Posted on Jun 26, 2007
SOURCE:
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
Kodak digital camera will not stay on. Lens retracts immediately.
Hi. I actually have the same EXACT problem. DId you end up fixing it. If so, how?
Mar 15, 2010 | Kodak Cameras
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
The camera will not stay on
try to use lithium batteries they are the stronger in the market, o just grab a fresh AA alkaline batteries, not the cheap batteries for clocks o remotes. otherwise it won't turn on
Oct 08, 2009 | Kodak MX1063 Digital Camera
Camera turns on then immediately turns off
Quick turnoff is normally a symptom of low battery power. Make sure that you have fresh/charged batteries in the camera. If fresh power doesn't solve the problem you will need professional service on the camera.
Bill B.
San Antonio
May 12, 2009 | Olympus Stylus 400 Digital Camera
Lens stays out
E18 is lens error. When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Jan 10, 2009 | Canon PowerShot SD200 / IXUS 30 Digital...
My camera will not turn on
Hey Aunt CC,
What is most likely happening is there is something obstructing the movement of the lens (like a piece of sand), and that is why it keeps powering down immediately when you turn the camera on. Another cause of this camera powering down immediately could be the battery cover or memory card cover is open. If those covers are not open I would have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Sony Cybershot S650 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Kyocera Finecam S4 Digital Camera Logo
63 people viewed this question
Top Kyocera Cameras Experts
Ekse
Pat McCabe
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
