Question about Radio Communications
Cellet Bluetooth headset will not charge like something wrong with the charger port.
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
rajthegreat
  • 92 Answers
SOURCE: Charging
just open the main board
and clean with solution
and give a little bit of heat with smd
Posted on Jan 16, 2008
  • 43 Answers
SOURCE: bluetooth won't charge
actully this is device hardware problem so try to change the device.
Posted on Mar 07, 2009
SOURCE: Jabra JX10 Bluetooth doesn't/won't charge
Not sure if this is a solution or if it occurred by chance. Like many on here, I put my Jabra JX10 away for a few months while not using it. The time come for me to need it once again and found that it was dead. Made an attempt to charge the unit with negative results. The unit would only show a green "charged" LED indicator as if the unit was fully charged. I tried plugging the unit into the charger multiple times, and took the cradle out of the loop and just used the AC cord alone. Still with the same results. I pulled the outside cover off (slowly), to be sure not to break the small fragile tabs that hold it in place. The battery takes up majority of the space. Removed the battery but DID NOT disconnect from unit. Plugged the charge cord into the unit and immediately got a red LED charging indicator. While charging, placed the battery back inside and put the outside cover back on. The unit continued to charge for a little over an hour before the green LED "charged" indicator came on. I used the unit throughout the day to test it with no problems. Not sure what removing the battery from unit did, especially when it was not disconnected, but it worked. I hope to see similar results.
Posted on Jun 09, 2009
SOURCE: Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Posted on Jul 13, 2009
I just bought th hv 800 bluetooth headset, when i
might indicate it is fully charged already .
Sep 23, 2014 | Radio Communications
Change battery?
try to isolate the problem, use other charger and if issue persists, well the battery is faulty and you need to contact jawbone for assistance.
Apr 28, 2013 | Jawbone ICON Bluetooth Headset
Can the explorer 220 be charged with any charger, or does it need its original chager??
This should pair up with any Micro USB port to charge. I have done this when I left my charger at home home and used the charger that my friend loaned me.
Good luck from Headsets Direct!
Sep 24, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do I charge a PLANTRONICS EXPLORER E220 BLUETOOTH HEADSET OEM E 220? Thanks
There are about 4 different chargers that can be used, look at the A/C charger with the micro USB port on it, part number 76772-03. You didn't say which you preferred.
Good luck from Headsets Direct - 800-914-7996.
Aug 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I lost the charger for the jabra bt135 bluetooth headset...where can i buy a new one?
Hey there sanjeev! There should be an USB port on the back of the headset, it is the micro-usb port. Therefore, if you have a cable from your camera, mp3 player or any other gadget that uses a micro-usb port, take their cable, plug it into the headset and let it charge! :D
I hope it helped! Take care! :)
Mar 04, 2011 | Jabra BT135 Bluetooth Headset
I have a voyager pro+, about a month old, and now the red light does not flash on when I press the 'on' button, or plug the charger into it. Any ideas?
If your are charging through the USB port, and you have put it in wrong at all at any time, the connection will be shot and it will not charge. If this is still under warranty try to see if you can get it replaced.
Dec 31, 2010 | Plantronics Voyager PRO Bluetooth Headset
My nokia BH 202 bluetooth headset is not charging
if the charger is not spoil t then the charging port in the headset is bad.
Nov 13, 2010 | Nokia BH-202 Bluetooth Headset
How do i charge my lg bluetooth headset with AC charger. I cannot find an adapter insert on the headset.
HI. You will need to remove the concealment cover on the charging port before you can connect the charger. The cover is on the opposite side of the volume button. It will have the initials "PWR" on the cover. Pull that off to expose the charging port.
Aug 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
