Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Flashing color in and out with popping sound
My tv just started to flash in and out of color. When it changes color I get this popping sound with the volume and then you can hear the program. This just constantly repeats itself. It stopped briefly the other day, then when I turned it back on today, the same problem was going on. Any help appreciated.
  • Tracy Countryman Jun 26, 2007
    I wanted to add that this only does so when watching tv. When watching a dvd it does not do it. I was thinking possibly the tuner. Are these replaceable or feasible to replace?
  • 398 Answers
This sounds like the solder joints have cracked on the AFT can inside the tuner, a common Sony problem. Removing the tuner, opening it up and resoldering the grounds and small transformers inside should clear it up.
Posted on Jun 27, 2007
SOURCE:
We have a Samsung #HLN5065WX/XAA that has started making a very strange noise and flashing "Check fan no. 2". The colors are also off. What can I do to fix this?
The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
Aug 20, 2011 | Samsung HLN5065W 50" Rear Projection...
Have a 50 inch hlp506w model samsung projector tv. it had wavy lines through it, and then turned off. it is continuing to try and turn on with the standby/temp and lamp lights flashing. replaced lamp...
Change the tv Ballast board too.This board only job are to help it to ignite the tv projection lamp. This tv also have a colors wheel design into it too.If tv have colors pictures flashes or Black& White flashes within it pictures or tv have grinding noises or humming sounds,than the tv colors wheel it is warp and dead.This tv colors wheel must be replaced,because the colors dis wheel is warn out.
Jul 05, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Heard a pop sound, lost color, now i get loud buzzing no picture lamp light flashing and it turns itself off and on
Color wheel need to be replaced, required color wheel is available in Samsung Parts, click the link to view image and price info.
Thanks.
Jun 25, 2011 | Samsung HL-P6163W 61" TV
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
Hello.... Samsung HL-P5063W Lamp LED blinks approximately 35 times followed by 1 long standby/temp light blink After this all 3 lights remain lit and flash....lamp/standby and timer makes a loud humming...
Sound like ur tv have two problems.The "lamp"LED light flashes,mean ur tv need a new projection bulb.The loud refrigerator sound,mean the tv colors wheel is dead,it spinning off of it axes motor.Hire a tv repairman to do this the colors wheel is hard change,because require take out many machanicals parts even to get to the colors wheel to change.The bulb is easy replaced,but he there pay him to put new one in.
May 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
TV Flashing colors
HEY WE HAVE A 72 INCH T.V AND IT KEEP POPPING UP DIFFERENT COLORS DURING T.V SHOWS WHY IS THAT WE JUST CHANGE THE LAMP IN THE T.V CAUSE IT HAD WENT OUT ON ME AND THAT WAS ABOUT 1YEAR AGO FROM MARCH13,2009 SO I WAS WOUNDING WHAT CAN WE DO OR ANYONE SAY EVEN IF IT IS THE LAMP CAUSE WE ARE STILL NOT SURE!!! THANK YOU E-MAIL ADDRESS IS [email protected]
Aug 01, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Samsung DLP made a "pop"
Sounds like your color wheel was warped and finally cracked and broke.
Jun 26, 2009 | Samsung DLP HL-P5663W 56" TV
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
I have a 6 year old Samsung PCJ522R 52" TV.
It sounds like at least one of 3 "IHVT",s popped. in short, a "IHVT" is a high voltage transformer. It will have to be replaced along with any other parts that were damaged in the process.
They do produce a strong odor when they pop!!
It is repairable but at a price. there is a good chance that parts will have to be ordered.
you might consider buying a new LCD HDTV instead of fixing this one.
Dec 27, 2007 | Samsung PCJ522R 52" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
