Question about Cameras
My camera battery wont charge, light keeps turning off on the charger...how do i fix it?
The charger light turns red when i insert the battery to charge and is meant to stay lite till it turns green to show charge is complete...however the red light turns off moments after the battery is inserted
  • 156 Answers
SOURCE: Battery and Charger problems
I have to agree with the previous commenters who called the support line- I was off the phone in less than 5 minutes with a new battery shipped free of charge. 1-800-435-7732
Congrats casio- I'm buying my next one from you too.
Posted on Nov 07, 2007
mcomijohns
  • 477 Answers
SOURCE: Wont Turn on at all - Casio Ex-z750
Contact the person @ www.digitalcamrepair.com he can repair it for you.
Posted on Jun 12, 2008
SOURCE: my casio camera battery does not charge
Simple solution  ! just wire a 9V battery postive to positive and negative to negative ( be careful not to interchange them ). hold it together for 30 seconds ! done !
All this does is give the battery diode inside, a boost ! so that its connectors are activated and Voila ! it works camera's now charging !
Posted on Feb 10, 2009
SOURCE: Cannot charge battery
Hola!!!!!
i had exactly the same problem!!!. I bought my exilim Z77 camera in america almost 8 months ago and on my 5 month i charged the battery and it seemed never to charge completelly. The red light of the charger was blinking all the time. I called customer service and they replaced the batery. This is totally free if u are on the year warantee.So yeah ... the problem is the batery not the charger
hope this can help
:D
Posted on May 21, 2009
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
ylu1 writes:
what i did was...
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
It wont turn on and there is a red flashing light
first check your batteries ,whether they are charged or not?and also try the hard reset method ,that is,remove the batteries and keep it removed for half an hour and then insert the battery and try again,it will help you
Aug 04, 2008 | Cameras
My Casio EX-Z18 charger light keeps on flashing. When I put the battery in the camera, it doesn't turn on. What is wrong?
My Casio EX-Z18 charger light keeps flashing red when i put the battery in to charge, it doesnt charge up therefore my camera doesny work. Can you hepl??
Aug 03, 2008 | Cameras
NV3 Camera - won't turn on or charge
have been having the same problem. Just pulled the lead out straight and stretched it and now it is charging red light on constantly. May have been a kink in the lead?
Jun 24, 2008 | Samsung NV3 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
When i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Jun 11, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Cameras Logo
96 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
