Question about GE GSS25LGM Side by Side Refrigerator
I have a high point side by side - GE GSS25LGM Side by Side Refrigerator
    Genius:
  • 1,669 Answers
SOOOO? wHAT'S THE PROBLEM?
Posted on Jan 03, 2013
Why balance a plane right side up or upside down will be better ?
High wing = right side up
Mid wing = either way
Low wing = upside down
the reason is that to be able to find that balance point there must be sufficient weight below the
point of contact (balance pins) that the model can be stabile otherwise you can just keep readjusting and never find the real point.
Nov 20, 2012 | Great Planes Toys
Locate high and low side of a/c system on 1995 isuzu trooper
High pressure side is smaller tube than the low pressure side. Also, there should be service points on both sides with caps over them, marked L for low pressure and H for high pressure.
Jun 12, 2011 | 1995 Isuzu Trooper
How do I adjust the low beam headlght on a 2006 Sabaru Tribecca B9
I have a similar problem. The adjustment screw adjusts both the high and lof beams. After changing the passenger side low beam, both sides then pointed at the ground. High beams were fine. I adjusted so the low beams are fine but now the high beams point straight up.
In talking with Subaru Service he said there is a "module". He said after changing the bulbs they should point down then auto-adjust back up. That didn't happen. I haven't found anything on such a module. He said it woul be $109 for adjusting the lights OR for the module.
If I find anything more I'll let you know.
Apr 10, 2011 | 2006 Subaru B9 Tribeca
Replaced blades duel deck high spot in cut grass on right hand side. thanks.Mower is rover lawn king.
Try leveling your deck beacuse it sounds like the right hand side of the deck is too high causing the high spots. move the mower to a flat surface, drop the deck to its lowest point and measure the deck height with a tape measure.
Nov 27, 2010 | Garden
2000 jeep grand cherokee refrigerant capacity (R134a), any common leak points, O-rings etc.
Capacity is aprrox 1.75 lbs with proper gauge (28 ozs). Leak points are many, low side port ,high side port, high and low cut off switches,evap inlet,compressor manifold,condensor inlet and outlet...to name a few.
Jul 13, 2010 | 2000 Jeep Grand Cherokee
What is low side in ac unit
the low side is the larger hose that goes back to the compressor.
the high side smaller line comes from the compressor to the to
the condenser ( or the unit in front of the raditor ) on any units
with r-134 from the factory the low side has a different fitting for
putting in freon. some high sides don't use any hose connectors
because there is a site glass in the line where the high side would connect.
Jun 21, 2010 | 1998 GMC Sonoma
Can you let me know the connection digram of transformer to capacitor with high voltage fuse in a microwave. Make is sharp
Since you posted this under R-1210 / R-1211 / R-1214, I can point you to the service manuals that cover those models here:
http://www.microwavedisplay.com/r1200_r1201_sm.pdf
http://www.microwavedisplay.com/r1210_r1211_sm.pdf
Those models don't have high voltage fuses, but the connection of a high voltage transformer to the capacitor is almost always the same, so they may help you.
The high voltage lead of the HV transformer connects to one side of the capacitor. Unless there's a fuse inline, nothing else is connected to this point. The other side of the capacitor is connected to the anode (non-stripe side) of the high voltage rectifier diode, and to the FA terminal of the magnetron.
If you still need help, feel free to contact me with your full model number.
May 15, 2010 | Sharp R-1210 Microwave Oven
A/c port low side 96 chevy tahoe
The largest hose is the low side.
Apr 15, 2009 | Heating & Cooling
Where to add refrigerant to a 1997 gmc sierra. It looks like there is 2 places 1 is pointing up and 1 is pointing out. 5.7 V8
Look on the threaded caps that cover the connections,on top of the caps one should have a L for lowside pressure and the other a H for high side.Add the refridgerant to the low side.If your doing it yourself and buying a ac recharge kit from a parts store or shopping center, the kit comes with the refridgerant and the hose you will need to recharge it.The hose fits only the low side connection on your ac line and willnot fit the high side,so you shouldnt have a problem.Hope this helps you.
Mar 05, 2009 | 2002 Chevrolet Venture Passanger
Ihave high-pointe microwave oven serial #0604m00024 manufactured/ april2006 and listed 54nj has benlocked and idont know how to worked please hellpme
I also have a High Pointe Microwave Model EM925BSC SN 0608MO3508 manufactured in Aug 06. Tried to use it for the first time this weekend after buying a new Honda EU2000I to use it. The turntable does not turn automatically or when I try to turn it manually. Cooks OK. Nothing in the owner's manual that came with trailer (Zoom 178) mention how to fix the problem.
Anyone have a Ph# for High Pointe. Their Service center address is High Pointe, 2617 N Great Southwest Parkway, #100 , Grand Prarie, TX 75050.
Jun 26, 2008 | Microwave Ovens
GE GSS25LGM Side by Side Refrigerator Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
