Question about Refrigerators
Westinghouse WSE6070SA broken water supply hose - how do I fix it
With water and ice dispenser
the dr
  • 447 Answers
SOURCE: kenmore fridge optical icemaker hosed
ice maker module assembly is probably broken
Posted on Sep 27, 2007
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 6 Answers
SOURCE: water dispenser dripping
HVACRH20, are you any good with GE water dispensers dripping? Let me know, I have a lot of info to provide and maybe you can help answer my problem?
Posted on Apr 02, 2008
  • 489 Answers
SOURCE: water dispenser not working
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Posted on Apr 27, 2008
  • 3 Answers
SOURCE: Ice maker issues
Replace the Motor Module on the ice maker. I had the exact same issue.
Posted on Aug 05, 2008
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
Neither ice dispenser or water dispenser work
00023391.gif small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
transparent1.gif Find a part for your Refrigerator godark_3.gif How Refrigerators work godark_3.gif What is wrong with your Refrigerator? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Refrigerator godark_3.gif Answers to common questions about Refrigerators (FAQ) godark_3.gif Locate your Refrigerator model number godark_3.gif Accessories for Refrigerators godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for yourRefrigerator and get free Refrigerator repair advice for all majorbrands of Refrigerators including Admiral, Amana, Crosley, Electrolux,Estate, Frigidaire, GE, Gibson, Glenwood, Goldstar, Hotpoint, JCPenney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag,Modern Maid, Montgomery Wards, Norge, RCA, Roper, Sanyo, Sub Zero,Tappan, Thermador, Westinghouse, Whirlpool, White-Westinghouse, andmore.
Jul 05, 2008 | KitchenAid Refrigerators
I have a Westinghouse side by side refridgerater with water and ice dispenser. The other day I arrived home to find water pouring through the back of the freezer section into the ice maker,and into ice...
Your water control has two sides. One side is for the ice maker and other is the water disapenser. If the ice maker valve becomes mechanically defective the water valve can allow water to continue to flow or not flow at all. Replace the water control valve and I believe this will solve this porblem, Thanks Sea Breeze
Dec 11, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Kenmore fridge optical icemaker hosed
Sep 27, 2007 | Refrigerators
I cannot get water out of the water dispenser and the icemaker isn't making ice.
is the water freezing up en route? try a full defrost to see. if not a blockage may have occured.
Jun 04, 2007 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
