Motherboard cant detect hard drive
Need to add drivers before loading OS?
  • 27,725 Answers
A faulty lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect / boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads power and data that attach to your hard drive,IDE,SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ? even something as small as a faulty fan lead can cause this problem a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail Hope this helps.
Posted on Jan 03, 2013
Beni S-P
  • 1006 Answers
SOURCE: Laptop can't detect seagate 200GB External Hard Drive 7200 rpm?
Is that external hdd???
Posted on Mar 13, 2008
SOURCE: hard drive reported at zero bytes
see after teh utility named Partition Magic, It will solve these typoe of errors. Another cheap option is to try to format it with a vintage computes BIOS, HDD Formattion option, Not available in newer BIOS.
Tyr aldo Fdisk /mbr in the DOS PROMPT , booting with D.O.S. Ver. 6.0 Anyone remember this Operating system?
And the last option is to format the drive undel LINUX and thern get it back to Windows XP.
Posted on Jan 03, 2009
  • 32 Answers
SOURCE: Sata hard disk drive on asus p4v8x-x motherboard
I have checked and you computer does use SATA drives. If you don't have a manual, send me your email and I will forward the manual @ no cost. The manual will show you where to insert the cables.
Posted on Jan 20, 2009
  • 523 Answers
SOURCE: unable to load os
check the operating system Cd could be bad version, try other one, if still the same , format your harddrive long way not the quick way.
Posted on Jul 11, 2009
  • 163 Answers
SOURCE: My western digital Passport 320Gb usb drive is not detected
U need to update windows XP , USB drivers will be installed
Posted on Dec 29, 2009
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample below:
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will be furnished after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Serial ATA cables. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the motherboard.
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar if possible.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    May 08, 2014 | ASUS K8V-MX Motherboard
    Dell xps 710 motherboard replaced with 700 motherboard but it does not boot
    This could be any number of problems. First start with hardware. Is everything seated and connected correctly? Are the hard drives installed correctly. Are the power on pins on the board set correctly or pinned at all? Is the ram the correct ram?
    Check the hard drives, are they functional, do they boot with other computers?
    Use a volt meter and check that the power supply is producing the correct voltages on all the connectors and rails.
    If that all checks out, it might be a bios error. Check your boot load order and if the motherboard is detecting the hard drives, check that the correct bios settings for OS management are in place as this is a server. Is the RAM power settings (voltage) and speed correctly selected? Will the computer boot from optical drive using a live CD? Will it boot from a USB live OS (like Ubuntu)?
    Since it's not booting, you may not have compatible hardware or damaged hardware. The OS that's installed on the hard drives may not be able to load on the new (older model) motherboard due to driver incompatibility.
    Oct 13, 2013 | Intel Server Board SE7501BR2 Motherboard
    K8V SE Deluxe board. B.I.O.S. Main on Auto, No Hard Drive Detected. Hard Drive is shown in Boot and RAID. Have checked all cables and tried a different HD. Cannot load O.S. from disc. Fails because...
    I think u have to download the driver for SATA drive!
    Read again ur owners manual and download the driver and procedure so that the bios can detect the SATA HD!
    Jun 13, 2011 | ASUS K8V-MX Motherboard
    WHY ASROCK MOTHERBOARD m266a cant detect the hard drive
    http://www.asrock.com/support/download.asp
    Follow this link and Down Load up dates and drivers. Thank YOU for Using FIXYA.
    Feb 26, 2011 | Asrock M266A Motherboard
    I recently replaced the motherboard, video card and hard drive in my dell d800. The hard drive is new, but when I try to boot-up the computer gives an error message that there is no hard drive detected....
    If it says there is no hard drive detected, then the BIOS is looking for one.
    When you place your system disk in the drive to load on a fresh system, if you are using Windows, it will automatically detect the pressence of a hard drive, initialize it and format it. If it doesn't, put the hard drive in a USB caddy and initialize it from another pc, then place it back in the notebook.
    Hope that helps.
    Nov 24, 2010 | Dell Latitude D800 Notebook
    Have you got a driver for this product please?
    usually hard drives dont need driver to be installed seperately, they ll be automatically detected by the operating system and bios. if not check cables,connections, power supply.... if still not working check with other system..
    Sep 18, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
    I am adding new 160 GB Sata HDD to my System and reformat new Hard disk but the time of installation hard disk not found. But check bios. they have already detected
    I have had the same problem. The problem is that you need to load the raid driver / controller when installing the OS. When you are installing the O/S like in the first 60 seconds of the install you hit F6. You must go to asus and download the raid or controller driver. That should take care of your issue. I think moving the hard drive to another channel on the motherboard might be an easier fix.
    Nov 15, 2009 | ASUS K8V-MX Motherboard
    HP Workstation xw8200
    Server 2008 is not detecting your drives, because it does not have drives for what ever hard drive controller you are using. You will need to determine which controller your drives are attached to and load the appropriate driver during setup. I believe this system has built in SCSI and SATA controller and often shipped with add - in storage cards. Our came with a promise sata raid controller.
    Apr 20, 2009 | HP xw8200 PC Desktop
    My Motherboard wont recognize my Hard Drive
    Is it Sata or IDE?.Also is your boot order set to the CD rom as the first device.The O.S is bootable only if the CD runs it first. Windows should format it later in the install process.
    Nov 25, 2008 | Computers & Internet
    Crashing during Windows Setup
    Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
    Sep 17, 2006 | Microsoft Windows XP Professional for PC
    Computers & Internet Logo
    David Payne
    David Payne
