Question about Compaq Inkjet IJ650 Printer
IJ650, Color and black print cartriges are out of sync.
I do not know how it happens, but the print cartridges are not synchronized, when I send something as simple as a rectangle filled in whatever color with an outer line in black the printer shifts down the black line forming two rectangles, one in color and one without fill, one shfted from the other one for about 2 mm. It seems as if the printer deceide to delay to print the black stuff delayed from the colored stuff. Any idea to fix this problem ?, I already reinstalled the software, that I got from the compaq website, aligned the heads, etc, nothing has been enough to resolve the issue. The test sheet of the printer shows one strange caracter at the begining of each line.
  • 186 Answers
Try changing the printer cable. Also have you cycled the printer on and off? Are yo using genuine manufacturer cartridges? The possibility is the paper feed rollers may need to be cleaned. Some are accessable and some are not. If you can see them try cleaning them with a rag and some rubbing alcohol.
Posted on Jun 26, 2007
SOURCE:
I want to know what inkjet i require for lJ650 printer please. any assistance would be helpful. thanks
Hi There, This printer is a Reamed LEXMARK Printer. they have all the printer inks for this unit on
http://www.inkjetonline.com.au/lexmark-compaq-ij650/
you can get high yield and twin packs here as well for the Color and Black cartriges.
if you are outside of Australia the ink tanks should be named the same just a different price so for the BLACK INK its a
Lexmark No 16 Black Ink Cartridge 10N0016
and for the colour ink its a
Lexmark No 26 Colour Ink Cartridge 10N0026
Hope this Helps
Feb 15, 2011 | Compaq Inkjet IJ650 Printer
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
What type of ink cartriges are used in the lexmark 5400 model
hello there
here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Both lights on Compaq IJ650 have started blinking. The printer was working fine; Connected to a desktop with XP Prof. There is no wrror message; After a brief delay the message comes that the ''Document...
I cleaned up the contact points area of the cartrige and the corresponding contact area on the printer cartridge case with a cloth wetted with nail polish remover. After it dried in about 2 or 3 minutes I reinstalled the cartridge & it is working fine.
Mar 22, 2009 | Compaq Inkjet IJ650 Printer
Compaq IJ650 ink jet printer will not print color.
Just because it’s new does not mean New Old Stock. Your print head is plugged. No if or buts about it. Contact HP and tell them you situation. If they don’t help you, box it up and take it back. Buy an Epson.
Jan 08, 2009 | Compaq Inkjet IJ650 Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printing RAINBOW of colors!
Change the color cartridge and see what happens.
Aug 06, 2008 | HP Deskjet 6940 InkJet Printer
Compaq Inkjet IJ650 Printer Logo
42 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Thomas F. Schneider
Damen Wong
Damen Wong
Alun Cox
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
