Question about Apple LED Cinema Display 27 inch flat panel
Have 23 inch cinema that will power on for 15-20 minutes then goes to sleep and the power button will not work . in my limited knowledge of electronics i was thinking that it could be a capacitor issue as it takes a day or so to get back to square 1. found it so 100 bucks for a used logic board dosn't make much sense as i can get a new monitor for 125 or so. has anyone had the same problem , or someone with some electronic back think it is worth replacing the capacitors.
    Top Expert:
  • Apple Master
  • 74,887 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jun 03, 2017
How do you get a Westinghouse 50 inch TV out of sleep mode
Go to sleep timer in menu and hit button until it goes from max sleep (i.e. 90 minutes) down to 0 minutes or off.
Jul 07, 2016 | Westinghouse Televison & Video
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
My monitor is in sleep mode and I cannot wake it up. I will press the power button on the side of the monitor and will get an occasional brief light to go on in the lower corner of the monitor frame. I...
May be it's he pc that's in sleep mode, try some keys on the keyboard to wake it up or try the function key plus f8 a couple times. Depends on what your setup is. Is there a other viewing hardware connected?
Mar 08, 2010 | Apple A1082 CINEMA DISPLAY 23" LCD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
I have power with my 23 inch apple cinema but no picture vga monitor works fine
pc and mac do not play nice together you may need another vga cable since mac may use different pinnout than pc monitors
May 09, 2008 | Apple Cinema HD 23" LCD Monitor
Screen does not turn on
Sounds like the 90w power adaptor. This has happened to my 23" Apple monitor several times. (I'm on my third 90 watt "brick"!) It seems to happen after about one year of use. All you can do in the meantime is never shut down or let the monitor go to sleep.
Oct 29, 2007 | Apple Cinema Display 23" HD Monitor
Apple LED Cinema Display 27 inch flat panel Logo
Top Apple Televison & Video Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
Are you an Apple Televison and Video Expert? Answer questions, earn points and help others
