Question about NAD T557 Player
Problems with firmware update - NAD T557 Player
There is a problem with the printer head
A firmware update will help resolve the problem that you're experiencing. Just go to http://bit.ly/ghfW8H to download the firmware update. Before applying the firmware update, you'll need to get rid of the error message. Just remove the printhead and close the cover of the printer then press cancel. Once the error message is gone you can then proceed with the firmware update.
If the problem persist after the firmware update. You'll have to call Lexmark's technical support.
May 22, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Tip
How to fix the problem with Belkin Next generation Routers ?
How to fix the various issues with Belkin Basic, Surf, Share, Play, PlayMax Routers ?
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
  • Login to the page. (password: leave it blank and click submit)
On the left side below the "utilities" select firmware update and check the current firmware version of your router.
In these updated firmwares all the problems related to various issues have been fixed.
download the latest firmware and update it.
After updating the firmware click on restore factory defaults found below the "utilities" and restore it.
then configure your router according to your internet service provider...
For Cable ISPs click here...
For embarq and centurylink ISPs click here...
For DSL & Satellite ISPs click here....
To configure the wireless part except for play & playmax click here...
on Jul 24, 2010 | Computers & Internet
Where can i find firmware updates for LG GSA-4163B dual layer burner - believe it to be A106
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).
The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
Hope this helps you
Aug 21, 2011 | LG (GSA4163B) DVD±RW Dual Layer...
I got the old 407291 software version on my machine and would like to upgrade my firmware, but LG says : Contact your dealer --- Please help
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
hope this helps
Aug 11, 2011 | LG BH08LS20 Blu-ray Burner
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
My tv works good. Will a firmware update be worth it or can it cause more problems than it is worth.
Usually firmware updates are made to resolve small issues, or to update comparability with new data formats. If anything, this might resolve some problems you'll have with your TV down the road if you don't update it now. So there should be no problem with a firmware update.
Mar 12, 2011 | Sharp LC-46D64U 46 in. LCD HDTV
Printhead not supported by this all in one
Try to re-seat the printhead on your Lexmark Pro901 printer. If problem continues, it could be firmware issue. There is a firmware update that addresses false printhead errors. You can easily download and install the firmware update by visiting the Lexmark website at http://bit.ly/P905FW.
If you encounter any problems applying the firmware update or if problem continues even after updating the firmware, please contact Lexmark technical support. I'm confident they can get it resolved for you. Thanks.
Dec 02, 2010 | Lexmark Pro901 All-In-One Inkjet Printer
Why haven't you found solutions for the posts above???
Hello joe_east,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Nokia 6230
this happens due to the firmware problem(this may be due to virus attack) ....
try giving the restore factory settings in your phone ...
if you still persist the problem then you just update the firmware of the phone that solves your problem ....
you can update the firmware with the normal datacable only ...
you can update to the latest firmware for your phone from the software called" Nokia Software Updater "...
you can download this for free from the website of nokia directly given below :
http://europe.nokia.com/A4579163
(your pc must be connected to net to download the latest firmware)
but remember dont disconnect the cell while updating the firmware is in process if you do so your phone will be severely damaged you can never use your phone ...
even the manufacture can t help with this if you interrupted during the firmware update ....
after you update the firmware all your problems will be solved ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 13, 2008 | Nokia 6230
PHONE WILL NOT CALL OR RECIEVE CALLS BUT DO EVERYTHING ELSE
this happens due to the firmware problem(this occurs due to virus attack) ....
butremember dont disconnect the cell while updating the firmware is inprocess if you do so your phone will be severely damaged you can neveruse your phone ...
thank you
bye
rate my solution
Jul 11, 2008 | Nokia N95 Cellular Phone
NAD T557 Player Logo
177 people viewed this question
Top NAD Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Raj Patel
 Grubhead
Grubhead
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
