Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu L7310 can i put a 15.4 screen from a d series onto a l series 15.4 screen
Fujitsu siemens amilo L7310 Laptop
Hello
OK, unfortunately you do not specify as to what the question is.
Please be more specific.
Kind regards
Andrea
Aug 27, 2010 | Computers & Internet
Hard drive info for Fujitsu T4210
Better late than never. See http://simshsia.wordpress.com/2008/07/15/disassembly-of-the-fujitsu-lifebook-t4200-series-tablet-pc/
I hope this helps. Should you have the original system restore disk ( or copy ), kindly get in touch.
Nov 03, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
My tv is blank after I connect the 15 pin cable to S6240 laptop
you have to enable eigther Daul Display in display properties or Cloned display. Most laptops have a funtion key (Fn) on the keyboard and an F key (usually F4) that toggles this funtion. the F key will have a picture of a screen on it.
Aug 17, 2009 | Fujitsu LifeBook S6240 Notebook
Take out the ram and put it back on Fujitsu S series LBS6130
Try reinsert the RAM in another slot. If there are two RAM chips then try reinserting one by one. Make sure that it sits on the slot properly
Jun 22, 2009 | Fujitsu LifeBook S7020 Notebook
I have a fujitsu C series lifebook and my display is black when i turn it on everything else works and if i hold it up to a light i can see the screen as it should appear
It's problem of the LCD converter, it's easy to replace. Take out the four screws at the corners of your screen (they are covered by rubber footing or a sticker), carefully take off the bezel, you should see a 6 inches long some sort of circuit board just above the keyboard, at the bottom of your screen. That's the inverter, check the model number and search for it on eBay, it's usually about $15 to $30 bucks. Replace it, and everything should back to normal.
Apr 08, 2009 | Fujitsu Lifebook C1020 Notebook
Screen replacement fujitsu l7310
what happened to the screen
you should always replace your screen with the proper model
sometimes cheaper to gat a new laptop
Jan 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
How to replace Amilo L7310 screen
unless you know what you doing, don't try it.
it is easy to take it apart. you will have hard time put it back together.
Oct 12, 2008 | Computers & Internet
Fujitsu Amilo L7310
I have L7310GW - maybe it is similar.
The BIOS battery is deep inside the case and needs full strip down to reach it. I know because I have just taken one apart. Need to undo all screws on base and remove keyboard and screws under that and hinge cover screws and steel plate under keyboard and remove mother board to find it.
Good luck
Jul 09, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
138 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
