Question about Lime Pro Equipment D7.3 Treadmill
Panel shows code error e06 - Lime Pro Equipment D7.3 Treadmill
Tengo un error E06 tengo 2 meses que compre el equipo espero puedan ayudarme mi correo es nicolas82191@hotmail.com
Posted on Jul 18, 2013
Hola, tengo el error que dice E06 y quiero saber como se quita, mi correo es consuelo_.yi@hotmail.com
Gracias
Posted on May 31, 2015
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
JVC GR-DVM55U Error E06
HI,
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
I lost my manual for Snappy Chef. I do not know if E06 appear what does it mean.
LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
Feb 02, 2015 | Ovens
Pz 50hv2
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Error code details to many brand TVs are given.
Jan 08, 2014 | Televison & Video
E06 and E01 error code
E06
Paper output cover is open. Close the paper output cover.
Nov 03, 2013 | Canon PIXMA Office Equipment & Supplies
Kenmore dishwasher error e06
the error is linked to the float switch at the base of the dishwasher. Without model number and some description of the condition of the dishwasher leading to the fault code would be helpful.
in the meantime see this site and this too.
Jan 01, 2013 | Kenmore Dishwashers
Error codes
If it a washer dryer e06 usually means its not draining, check the filter (bottom, behind plinth). If it is just a washing machine it is possibly a heating fault.
Nov 21, 2011 | Bosch Washing Machines
Jvc gr-d350u. Constant E06 code with either battery or power adapter
if the screen keeps showing e06 device is in safeguard mode """"please remove or reattach the battery""""" If the error continues, please understand that it is a FAULTY BATTERY. This error is very common and results when the battery life has been changed or altered due to time elapsing. There is not a lot that can be done except to request a new battery. I performed more research on this and found that an equivilent may be purchased directly from jvc.com for a fraction of the costs then replacing the entire unit.
Jan 11, 2011 | JVC GR-D347U Camcorder
I have a BOSCH washer/dryer WVTI2840 which keeps showing the error code E06. I have checked the pump and also had a new one fitted! The code still appears but now the machine will not spin on a rinse spin...
This error is indicating drain problem.You will have to manually drain the machine. E06 is a draining problem.
When you took the filter out did you check there was nothing jamming the impeller at the back?
Make sure the impeller turns ok. It should ping round in stages.
Also check were it drains to. If under a sink check the pipes there.
If after that its still not draining then its likely to be the pump which is faulty.If you have already replaced the pump then check the connection of pump to the hose.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 31, 2010 | Washing Machines
Smeg wm16aaa error code e06 Can anybody help me on the above please
HEre's a link to Smeg's web site with all the error codes:
http://www.smeg-service.co.uk/support/index.php?a=1#1
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
G
Nov 08, 2008 | Smeg WM16AAA Front Load Washer
Lime Pro Equipment D7.3 Treadmill Logo
1,228 people viewed this question
Top Lime Pro Equipment Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Lime Pro Equipment Exercise and Fitnes Expert? Answer questions, earn points and help others
