Question about PC Chips P21G (881038000916) Motherboard
Cpu fan still running even the system was shutdown
I shutdown the computer with the normal way "click Start>Shut Down..
when all the system was shutdown only the cpu fan still running..
help me..
  • 741 Answers
Unplug your computer from the wall socket. Then the only power it will have is the battery that keeps the CMOS information. There will not be enough power for anything to run.
Don't forget to rate this solution.
Posted on Jan 19, 2009
ACER ASPIRE X1200 Unexpected Shutdown
When does it shut down? Are you able to use it at all? Or does it shut down when you are trying to boot it up?
When it shuts down are you able to boot it right back up and start using it? If not, it might be running hot. If you let it sit a while to cool off then try booting and if you are successful, then it is definitely running hot.
Three things that will make a computer run hot.
1. Dust - Dust inside the computer, dust clogging the vents and fans. Dust around the cpu and heat sink. To fix, Remove the power cord, remove the case and take a can of compress air to blow out the dust.
2. A fan is not working. Make sure the fan inside the Power supply and the fan that sits on top of the cpu is working. Normally the system will notify you if the fan is not working. To fix, you will have to replace a fan that is not working.
3. The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool. To fix, apply a fresh coat of Thermal Paste around the cpu and heat sink.
Maybe you have a virus or infection that is shutting you down if it is not running hot and you are allowed to work on the computer for a while before it shuts down. Boot the System in Safe Mode and see if it shuts down.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
May 24, 2012 | Acer Computers & Internet
How can i tell if the fan on my vaio CS31S isnt working properly? It seems to speed up and down and the laptop shuts down? Is it te fan or could there be another reason for this shutdown? :-)
Try blowing out any dust from around the fan with compressed air. If the fan is turning on and off a lot, this could be normal, depending on your processor, but if the system just shuts down fully and randomly, it would be a heat issue. The CPU is overheating and the failsafe mechanism is to instantly shut your computer down. The only way to avoid this is to raise the CPU shutdown temp in the BIOS settings, or if you can access the CPU, remove it and apply new, quality thermal grease. Also, ensure the fan is operating correctly during use and dont block any air intake or exhaust ports.
Mar 08, 2011 | Sony CPU FAN CPU Fan
Acer t310 fan runs when shutdown
More than likely the cpu is still hot even after you shut off you computer, so as a saftey precaution the fan is trying to cool it down,(which is a good thing).
Jan 06, 2009 | Acer Aspire™ T180 PC Desktop
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Think pad T30 - very slow to shut down
Your computer needs a clean.
Be sure that your computer is not virus or spyware infected.
Check if the fan is working, another cause could be related to a hardware issue.
Oct 09, 2008 | IBM ThinkPad T30 2366 Notebook
System shutdown
Systems that shut down after being powered on can point to an over heating of the CPU. Other factors come into play with overheating. Too much dust build-up on & under the CPU fan blades. Dust builds up in-between the heatsink fins (Thus the CPU fan can not cool the CPU chip.)
The CPU fan may be running too slow. When the PC system shuts down it’s saving you from hurting the system. You did not list the model number of you're system. Check you're system & clean the mentioned parts. Use canned air & a dry clean small paint brush to help remove possible dust buildup blow the dust away with the canned air.
Mike
Jul 23, 2008 | Intel Motherboard
CPU fan stops, computer shuts down
You must have the CPU fan plugged into the CPU fan power connector or the system can not monitor the fans speed. Your PC will shut down & give you that message. (The fan must be connected to the correct power plug).
If when you did replace the CPU's fan & had to remove the heat sink, which is where the fan screws into & did not clean the old thermal grease off the CPU & heatsink & replace with new thermal grease than your CPU will still overheat. If you add thermal grease over top of old thermal grease your CPU will over heat.
This is all a balancing act. If any one is not correct your system will shut down. (This is better than killing the CPU).
To remove old thermal grease use a clean cloth damped with house hold alcohol & use the same on the bottom of the heatsink. Please allow plenty of time for the alcohol to dry.
Good Luck! Take your time.
Mike
Mar 30, 2008 | HP (P2074-63003) Motherboard
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63446
Mike
Mar 24, 2008 | Computers & Internet
Shut down problem
if it gives you 60 secs warning , abort the shutdown by ---- shutdown /a---- command....and check for any servivice termination from administrative tools > services... check if all the automatic strted services are running
Jan 26, 2008 | Microsoft Windows Server Standard 2003 for...
PC Chips P21G (881038000916) Motherboard Logo
155 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
