Question about SanDisk Sansa e200 MP3 Player
Sandisk e200 My sansa e200 keeps freezing at the startup (the sandisk logo) how do i fix thiss?? mee
  • 4 more comments
  • mee mee Jun 26, 2007
    i tried to restart it but it freezes and the restore doesnt work
    I removed all of the songs and it still freezes, thanks for the help
    Ive tried everything, i need helpp
  • mee mee Jun 27, 2007
    how do you reset the player?
  • JsJs Nov 09, 2007
    my sansa will refresh itself and berfore it loads all the way it makes a whole bunch of funny colors!!!!
  • overkill250 Dec 29, 2007
    My e250 is stuck on the startup menu, the sandisk logo, I have reset it by holding the menu button and whatever, but when i turn it back on it freezes once again on the start up menu. sometimes when I push the button in the middle of the player the screen goes completely white, resets itself and freezes at the SAME SCREEN!!!!!!!
Press menu once right after it frezzes
Posted on Jun 29, 2007
Its just startup issue remove all the songs and u might see reset ... and see
Posted on Jun 26, 2007
Press the middle of the player and the menu button at the same time for like 30 seconds or more and it turns off and try it again
Posted on Oct 15, 2007
SOURCE:
I erased some things i didn't think i would need from the mp3 player (photo folder, etc.) and now when it turns on it just says "Load main image failed, switch to recovery mode"
STEP 1: Soft Reset
Simply press and hold the power button for 20 seconds. The soft reset would refresh the player. After doing the soft reset, try to turn on the player once more. If this didn't resolve your issue continue to step 2.
STEP 2: Firmware Update
Firmware controls the functions of your device (how your device operates). In cases where the product does not perform as intended, the update fixes the issue by replacing the current firmware with the latest enhanced version.
Please be reminded that for your player to work properly you need to meet the requirements below.
- Windows XP SP2 or higher
- Windows Media Player 10 or 11
To Download the Sansa Firmware Updater, you may copy and paste this link to the address bar of your web browser:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
To Know More on Using the Sansa Firmware Updater:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=306
If you encounter any issues with the Sansa Firmware Updater, we can try to use the Manual Firmware Update.
There are three versions of the Sansa e200 - Version 1, Version 2, and Rhapsody. This can be found by going over to "Settings" if you found "format" then you have a "v2" or look at the back of your player and check the exact model number under the "CE" logo it should say "model:e200" for Version 1; "model:e200 V2" for Version 2; and "model:e200R" for Rhapsody Version. Make sure that you choose the correct firmware version for your device as updating it using the wrong firmware version may render your device useless.
E200 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=15209
E200V2 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=13548
E200R Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200R&thread.id=2280
Dec 25, 2010 | SanDisk Sansa e200 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
My mp3 freezes up after playing awhile
Usually freezing is resolved via a firmware upgrade - check the manufacturer's website. Sansa players are manufactured by Sandisk.
Feb 28, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e200 6MB does not start correctly
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Mar 26, 2008 | SanDisk Sansa e200 MP3 Player
My Sansa E200 Problem
Sandisk can be very finicky about picking up throught the computer.  You may have to return the product for another.  Better yet, ask your sandisk dealer for a new usb cord!  The conductors connecting both devices could be loose and not have anything to do with the machine.
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 No USB Menu Option?
e200 or c200? I know that problem was fixed on the e200 with the latest firmware update. Download the sansa updater utility at the sandisk website and see if you can upgrade your firmware.
Jan 06, 2008 | SanDisk Sansa e200 MP3 Player
Sansa E200
You may have uploaded the incorrect or have had unstable power connected to your Sansa E200 when updating. If that is so, your Sansa E200 has been bricked and it's useless. This is the correct Sansa E200 Firmware Updater, "http://www.sandisk.com/Retail/Default.aspx?CatID=1376" (Note: Sandisk is Sansa)
Aug 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
99 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
