I can't Save wht I play in the gym battles or go to the professor lab eather.
Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
SOURCE: Nintendo 64 Pokemon Stadium Transfer Pak Error
Its most likely the controller. When you put in the pack is it loose? You could try cleaning the GB game and trying again.
SOURCE: Nintendo 64 Transfer Pak...
Try cleaing the contacts on the games and the transfer pak itself, look up how to clean games on youtube.
SOURCE: pokemon stadium, and transfer pak
hey i had tried to use the GB tower seens i have the nrage
but the game frezes when i select the gamepack please
help
