No display on the screen everything is ok why?
SOURCE: HP Pavilion DV1000 not charging the battery
yes its u r mother board battery connector problem...in the mother board there is IC for sensoring DC supply..near the battery connector..plase check the IC is working properly with A logic probe.if it not working plaese replace the IC with a blower..
SOURCE: HP Pavilion dv2000 overheating problem
did you make sure that the fan is running? also alot of people run their laptops on the bed. thats a no no. the computer does not get air and it can damage the cpu
SOURCE: display not working for HP pavilion dv2000
Try to attach your computer to an external monitor to see if it is a screen issue or a motherboard issue. If the computer does not pick up on the external right away, try to toggle it by holding down the Fn key and striking F4. If you get a picture on the external, then you have only lost the screen and the motherboard shouyld be fine.
Testimonial: "How do I do that?"
SOURCE: screen wont turn on
remove the battery and the power from the laptop.....then press and hold down the power button for 20 seconds ...... attach the AC power only and turn on the laptop this should turn on the system.
This drains the capacitors on the system (safety feature of laptops ... quite common)
If this does not work remove the Ram and reseat it ... something has either come loose or the backlight on the LCD has gone bad.
