Question about Kensington Ci75m Wireless Notebook Mouse In White With Silver - K72298us
Kensington K72297 Wireless Notebook Mouse problem
Working sporadically so I changed batteries, now it doesn't work at all - unless I plug in the cord to the USB.
  • Lola Emery Jan 03, 2013
    I solved my own problem (my husband did)!  I had put the new batteries in backwards, it wasn't marked good - but he figured out the right way.... NOW it works !!!
  • Lola Emery Jan 04, 2013
    As of my last post... I solved my own problem... I had the new batteries in backwards so no wonder it wouldn't work. With them inn right - it now works GOOD!
SOURCE: wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
Posted on Jan 11, 2009
yooperbud
  • 8637 Answers
SOURCE: Kensington Mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
yooperbud
  • 8637 Answers
SOURCE: how to install batteries on kensington wireless mouse 72214
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 22, 2009
  • 1602 Answers
SOURCE: Button works intermittently on Kensington Wireless Mouse P/N 6439
battarys maybe running low on juice or the ball may have oil on ball, look for reset switch on buttom of mouse press on it,
if info ray type clean the light area, reset the mouse and the usb plug in usb mouse adapter, it may be colored ot not, should be the same color as the mouse one is reset both at the same time.
rod
Posted on Feb 06, 2009
shaddow4115
  • 105 Answers
SOURCE: My Kensington wireless keyboard (Ci70)
Replace batteries in keyboard and re-sync the devices
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Synching Mouse or Keyboard with Wireless Optical Desktop trnsp.gif Question My mouse or keyboard doesn't work with my Wireless Optical Desktop (Model Number: 64373). What's wrong and how do I fix this problem? trnsp.gif Answer Your mouse or keyboard has lost its sychronization with the Wireless Optical Desktop, which can occur after changing the batteries, for example.
To synchronize your wireless device with its receiver:
  1. Move the device within three (3) feet of the receiver.
  2. Press the button on the receiver.
    If the receiver has an LED, the light blinks.
  3. Within ten (10) seconds, press the button on the underside of your wireless device.
    If the receiver has an LED, the light glows solidly when synchronization is successful.
Early production units of some wireless devices may require repeating the above instructions two or three times.
Timing, distance, and objects impeding the wireless signal may influence your success. While usually unnecessary, some customers have reported better results by:
  • Holding the wireless device very close, within three (3) inches of the receiver.
  • Entirely ignoring the receiver's light.
  • Simultaneously holding the buttons on both the receiver and the device for from ten (10) to twenty (20) seconds.
Posted on Dec 13, 2009
Kensington mouse reset after changing batteries?
reboot your system and see if it reconnects, if not remove your receiver reboot your system plug your reciever in on your desk top
it should say adding new hardware, or found on the buttom of you mouse it should be a pairing button press and hold down led should
flash and reconnect if not call the manufactor/
Nov 29, 2013 | Kensington Computers & Internet
Mouse problem
Update and install the newest hardware drivers from the Microsoft site. This should correct your problem. Yes, I know it will work Plug & Play, it just doesn't work properly. The other issue is batteries... use the most expensive batteries you can afford and never rechargeables as the voltage is less 1.25 V vs. 1.5 V.
Aug 27, 2012 | Microsoft Wireless Notebook Presenter...
Logitech wireless laser mouse not working my computer
If your computer has Windows XP or later your computer should automatically install generic drivers for it so that it works. So if that's the case and it still doesn't work then try changing the battery in the mouse, or plug the wireless adapter for the mouse in a different USB port.
Jun 25, 2012 | Acer Computers & Internet
I successfully installed the driver for the Kensington pocket mouse on my S7 notebook, but I cannot activate it to take over the job of the touch pad.
Wireless Installation
Plug in the receiver to your usb port. Install batteries to mouse.
To establish a wireless connection, press the connect
button on the end of the receiver. Then, press the
connect button on the bottom of the mouse.
Click a button on the mouse to go..
Repeat this procedure when replacing the batteries.
IMPORTANT: This wireless device is similar to an FM radio, by
adjusting the antenna you can get better reception. You may
also want to experiment with different locations and positions
of the receiver.
The little light on the receiver should light up and flash fast untill it sees the mouse signal.
Nov 18, 2010 | Kensington PocketMouse 72214
Kensington Wireless keyboard not working!!
Did u press the button on the reciver and the button underneath the keyboard so they can find each other? Try another set of batteries too.
Mar 04, 2010 | ACCO Brands Kensington PilotBoard Wireless...
My optical mouse Kensington Ci60 stopped working. Changed batteries and still not working ... How can I fix it?
Unplug the USB receiver and plug into a different USB port if available. Press the connect button on the receiver and wiggle and click the mouse for the next 10-20 seconds. This should revive the mouse.
If the above does not work, you may have to reinstall the drivers.
I hope this helps.
Nov 14, 2009 | ACCO Brands Kensington Ci60 Mouse
Mouse stopped working
Check underneath for dirt or debris blocking the laser light lens, try on a different surface ie (mousepad). If that doesn't solve your problem, it's time for a new one.
Jun 19, 2009 | ACCO Brands Kensington o - Laser Si750m LE...
rod
Feb 06, 2009 | Kensington PilotBoard 64385
Kensington PilotBoard Wireless Desktop Model#64379 - Mouse does not work
THERE WILL BE ONE BUTTON DOWNSIDE OF MOUSE PRESS IT CONTINUOUSLY TILL IT GETS SYNCHRONISES WITH YOUR PC.
TRY CHANING THE BATTERY AS WELL.
REGARDS
RAFIQUE
Feb 24, 2008 | Computers & Internet
Kensington Mouse
Nov 28, 2007 | Kensington PilotMouse Laser Wireless...
Kensington Ci75m Wireless Notebook Mouse In White With Silver - K72298us Logo
Top Kensington Video Cameras Experts
Are you a Kensington Video Camera Expert? Answer questions, earn points and help others
