Question about Philips HTS-3555 System
Where can I buy replacement connectors?
The connector for the SW3544E speaker (SW 3544) on my hts 3555 system has come apart. I haven't been able to find the part in connector catalogs. Can you tell me where to buy it and/or the part specification?
Have you found them yet? If not go to ebay and look for bogue engineering products, they should have it.
Posted on Mar 25, 2009
Hi all, I have a Philips Lx 3600 Dvd HTS and the DVD is not working. I would like to replace it, but it is also the builtin amplifier for the 5.1 system. Is it possible to buy another DVD/amplifier that is...
I have the same issue but it looks like buy a cheap philips DVD 5.1 with the EASY CONNECTORS and link to your existing speaker set. The new speakers can act as a fall back to your existing set.
Jul 20, 2011 | Philips LX3600D System
The power supply, LCP106830-0001 is bad. I need a schematic for Philips HTS-3555/37 and new poser supply to repair.
You won't get voltage if you completely disconnect the lcp106830 power supply from the board. The connection to the front panel is required and is used as feedback. I just repaired one and found one of the power diodes faulty.
Dec 20, 2010 | Philips HTS-3555 System
I have a Phillips HTS HTIB and would like to know if I can add to the speaker wire length by splicing?
Any splicing to a cable will degrade the signal quality and will compromise the integrity of the cable itself.
As a repair maybe for a short-term fix, but I wouldn't recommend cutting up a good system.
Nov 18, 2010 | Philips HTS-3555 System
Need to order A replacement DVD Player for this model
Unfortunately the player is not supplied as a standalone retail item. If your unit has failed under warranty then you must contact Philips in your country for servicing/repairs.
If the player is outside of the warranty then your only option to to replace either the entire system or to buy a different player which is compatible with your speaker system.
Oct 06, 2010 | Philips HTS-3555 System
Need a replacement remote control for the Phillips HTS-3555 system, where can i get a replacement remote control
You can buy required remote control for HTS-3555 from Remotes.com
Click above link to see required remote price info.
Thanks.
Sep 06, 2010 | Philips HTS-3555 System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Plays cds not dvds
Hai,
This is is due the lense and motor section problem, to resolve this issue you need to replace the lense and motor set.
Feb 11, 2009 | Philips HTS-3555 System
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Unlock HTS 3555
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
May 05, 2008 | Philips HTS-3555 System
Philips HTS-3555 System Logo
325 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
