Question about Chamberlain Wd822kd Whisper Drive 1/2-HP Belt Drive Garage Door Op
Just installed a model WD822KD, am not happy with it. Very noisy...
This unit replaced a Craftsman belt drive which had been installed for 7 years. The new unit looks exactly like the Crafsman. I am very unhappy with this one. It is very noisy...Might there be something I can look for to see if I might be able to quiet it down? The crafsman was so quiet you could hardly hear it, this one makes a whining noise when operating. I look forward to a reply, hopefully with a suggestion as to how to remedy the noise. Thank you, Lee Kaskisto
  • Chamberlain Master
  • 2,878 Answers
Operating Systems refers to computers. Try posting in another sections for better solutions. gl
Posted on Jan 03, 2013
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I would like to know what inspections/maintenence should be performed on drill presses, say monthly and than yearly. I want my machine to stay in tip top shape.
Depending on how much the Drill Press is used will determine the maintenance required.
For light to moderate usage a monthly clean and lubrication of turning / sliding parts with a general inspection of drive belts and pulleys will be sufficient. Heavier usage will require more frequent cleaning, lubrication and inspection.
Yearly maintenance will be the same as the monthly check with possible replacement of the drive belt if showing signs of wear or deterioration such as cracking and checking bearings of drive motor for signs of wear or noisy operation. If possible, an electrical safety check should also be carried out at this time by a suitably qualified person.
Feb 16, 2011 | Craftsman 12" Drill Press (21914)
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
Craftsman Mower Directions
Go to searspartsdirect.com and enter your model number in the space on the right of the page. When the list of illustrations comes up click on ground drive. This will show you the correct installation of the drive belt. Or do you mean " How the Heck do you put this on?"
Jun 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change secondary drive belt
Hello kerry_byrum:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select Ground Drive for a Breakdown of the Belt and Other Drive Related Components.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Older Sears craftsman 15 hp 6 speed. Let clutch out and
Hello:
From your Description it Sounds like a Bad/Weak Clutch/Brake Tension Spring.
I have Just Joined this Site as an Expert and can Assist you Better if you Send me the Model Numbers Off the Unit.
Good Luck
Respectfully
jbridger
May 11, 2009 | Garden
We need to remove the belt
Hello ttourek:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select the Dround Drive for a View of the Belt and Other Related Components.
Good Luck
Respectfully
jbridger (John)
May 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
May 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Chamberlain Wd822kd Whisper Drive 1/2-HP Belt Drive Garage Door Op Logo
113 people viewed this question
Top Chamberlain Computers & Internet Experts
David Payne
David Payne
Are you a Chamberlain Computer and Internet Expert? Answer questions, earn points and help others
