Question about Yamaha Audio Players & Recorders
Yamaha rx-v630 in silent mode without headset plug into it
The receiver is showing that a headphone is connected to it
  • Patrick Virgo Jan 05, 2013
    no headphone is connected to the unit and all the wires are connected
    Genius:
  • Yamaha Master
  • 1,054 Answers
Either the headphone jack is bad, or the cable from the headphone pcb is disconnected. Look inside the unit and follow the cable from the headphone board and make sure it is plugged into the main pcb.
Posted on Jan 03, 2013
4 Suggested Answers
SOURCE: Yamaha RX-V630 Doesn't power on!
I have the same problem.
Posted on Sep 04, 2008
  • 127 Answers
SOURCE: Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Posted on Mar 02, 2010
dunnbiker
  • 8546 Answers
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
Posted on Apr 30, 2010
How to connect a turntable to Yamaha Rx-v630
If your turn table has a ground wire with the R and L wires then you can not connect it to this receiver. Unless you have a switch on the turn table that chooses between internal or external amp. If you have the switch, pick external amp and then run your R and L into your TV/CD input. Good luck to you.
Jun 06, 2016 | Yamaha RX-V630 Receiver
How do I hook up an equalizer to my Yamaha RX-V630 Receiver ?
you hook it up through your tape monator just like you were hooking a tape deck up if you have a tape deck pluged in there you should be able to plug it in to the back of equalizer the same way
Sep 08, 2014 | Yamaha RX-V630 Receiver
Stuck in headphone mode
There should be a cable going to the headphone pcb. If you unplug that cable, it should clear the false h/p detection that is happening. Of course, you won't be able to use the headphones then. To completely fix it, you would have to replace the headphone jack.
Jun 19, 2013 | Yamaha Audio Players & Recorders
Yamaha receiver silent cinema
are there headphones plugged in? Otherwise something is wrong with the headphone jack probably.
Apr 21, 2013 | Yamaha RX-V363 Receiver
Just clicks no power. Already checked for touching wires and proper cooling. This unit has worked fin in the same location for four years. Any other ideas?
I had a similar 'drop out' problem with my Yamaha RX-V3300.
Problem- Possibly loose speaker connections.
I have banana connections which I unplugged; tightened speaker terminal connections at back of receiver and then reinserted banana speaker connectors- which remedied problem. There is possibly some kind of loose connection either caused by the banana plugs or at speaker connectors at the back of the receiver, which was remedied (i.e. possibly temporarily) by reinserting the banana plugs.
I also previously thought something was wrong with the main on/off power relay which was 'dropping out' and replaced it, but then 'drop out' problem returned a few days later. I reinserted and tightened speaker connectors, which has it working again.
Dec 22, 2009 | Yamaha RX-V630 Receiver
Yamaha RX-V630 Is not responding to the remote control unit
Replace the remote control with a universal remote (e.g. Logitech). It is more advanced and very user friendly with a help function if anything doesn't work.
Just follow the instructions in the unit's manual.
If you drop it; be sure to replace the batteries correctly.
Keep good batteries in it and enjoy the convenience of only one remote.
If still in trouble; just visit your local Yamaha dealer for help.
Jul 11, 2009 | Yamaha RX-V630 Receiver
Los receivers traen un transformador este trae un fusible termico quizas este dañado por eso no enciende.O los amplificadores de audio estan dañados checa desoldandolos.
Apr 04, 2008 | Yamaha RX-V630 Receiver
Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Jun 05, 2007 | Yamaha RX-V630 Receiver
111 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
