Satillite l645 no picture
When I turned my laptop on the lights in front came on,something clicked inside as though everything was starting up only I have no picture.
    Problem Solver:
  • 11 Answers
Try tapping(gently) the top of laptop screen when open mine often loses picture i do this and its fine again.
Posted on Jan 02, 2013
Toshiba satellie l645 turn off after 1min
Do you get any error messages? If so, post them here. Otherwise, I'd say it's overheating. Make sure all the vents and openings are clear of any dust or fuzz. If you're comfortable taking it apart, see if you can clean the fan for the processor
May 13, 2014 | Toshiba Satellite L645-s4102 Notebook
My laptop open media player at start, how can i change that
Click on START - All Programs - Startup ----> Now look at the shortcuts that are inside this folder. If you see your media player inside right click on it and press delete.
For more information you could specify what media player it is.
May 01, 2013 | Packard Bell Computers & Internet
How to solve Toshiba satellite L645 From black screen ?
You may have a faulty inverter, it supplies high voltage to the CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Nov 27, 2012 | Toshiba Satellite L645-s4102 Notebook
I'm having problem with Intel Extreme Graphics in my Toshiba L645-S4102
Test all leads that attach to your hard drive including electrical extensions EIDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure dust free connections and are not faulty or just replace them they might be faulty
you might have a dirty graphics card if you remove your graphics card clean both card and socket restart your computer then reinstall it this should activate found new hardware wizard
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it
or you might try these
http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance
hope this helps
Jun 27, 2012 | Toshiba Satellite L645-s4102 Notebook
Took my jeep though a water hole and the second it went into the water it turned off now it wont start all it does is click and sometimes it tries to start everything on the inside works fine though I...
Give it a couple days, hopefully it dries out. Charge the battery in the meantime, Hopefull you didnt hydro the cylinders and damage something. You didnt specify how deep you went
Nov 08, 2009 | 2006 Jeep Commander
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
The drum of my Kenmore 80 series electric dryer is not turning
sounds like you need a new drum belt. start by taking the top off then the front panel will have screws inside for removing the front. then once the front is off you will see the motor and where the belt should be. if the belt is broken, replace it, if not just put it back on the motor and idler pulley.
Dec 28, 2008 | Kenmore 659 Electric Dryer
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Toshiba Satillite A100 not powering up
hi
again $ again try 3 or 4 time to powerin on with ac mode,if not powering on then try it in backup mode with support battery if u dont have battery backup then get a battrey from any other laptop but it must be same model if powering on then change your adapter and try again if then also not warking go to nearer vender or service center.
by by.
Nov 18, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
