Question about Vacuums
Replacing acoustic foam in shhopvac QL50
While waiting for parts I forgot exactly how to replace the acoustic foam. Need a picture.
  • Vacuums Master
  • 18,408 Answers
Go to this link and there are some video's that will help you,,,,
http://www.ehow.co.uk/videos-on_4811_care-portable-shop-vac.html
Posted on Jan 03, 2013
Shark NV350NZ NEED 2Filters 1 foam 1 falt and pipe on rotating head were I get them and price please
Shark Vacuum Parts & Accessories ' eBay
www.ebay.com/sch/Shark-Vacuum-Parts-Accessories/42146/bn_7722312/i.html
  1. Cached
Shark Professional Rotator Lift Away UV560 Floor Nozzle Part NV501 HEAD ... Shark NV400 Rotator Rocket Vacuum Cleaner Motorized Floor Nozzle lower ...
You can obtain parts from the above. Quote model number.
May 24, 2016 | Shark Vacuums
It runs but not pick up dirt in cup
Hello! If the dirt is not entering into the dirt cup this could mean there is a clog in the vacuum or a filter that needs to be cleaned or replaced. Check that the brushes are still spinning. The vacuum has a brush-roll shut-off pedal on the right side of the cleaner if you are standing behind it. Below are simple instructions for checking your vacuum for clogs.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
9. Inspect the belt for damages, if the belt is broken replace the belt with a Genuine Hoover belt part 562633001 Flat Belt Nano Upright
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Mar 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
Need replacement roller
This is a link to Sears website. They have replacement parts for a ton of household items. If you look on your id plate on the vac post your exact model number here and I'll go look up the exact part, however, the one I found is in this link and it looks just like your vac. So This may already be the right one. and for 27 bucks it's not too bad. http://www.searspartsdirect.com/partsdirect/part-model/Eureka-Parts/All-Products-Parts/Model-4700A/1281/0645000/50031517/00001?blt=06&prst=&shdMod=4700A Hope this helps you
Jun 20, 2012 | Eureka Power Plus 4703D Bagless Upright...
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-parts-schematic.pdf
Also, here's the link to the owners manual for your model as well:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/bissell-lift-off-revolution-owners-manual.pdf
I hope this helps you,
Chris J.
GoVacuum
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
How long do I wait for it to crystalize and vacuume up?
I am assuming you are referring to the dry foam shampoo. After applying the dry foam shampoo down, wait about 10 minutes to go back over it and pick up the what ever is left over with the shampooer. Then wait till the carpet is completely dry (about 30 minutes to 1.5 hours) before you vacuum.
Oct 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Rainbow will not come back on
Bad idea.... I think the foam got through the separator and into the fan system. When it dried it hardened and now it need to be taken apart and cleaned.
Turn it on for less than 1 sec and if you hear motor making humming sound - it is ALIVE and cleaning (maybe new fan blades too) may be all that it needs. If no sound at all it may be KAPUT. You must have smelled something burning when you turned on and it did not work.
for D4 and SE models - When cleaning I would recommend to replace bearings as they are not that expensive and if you took it apart - maybe a good idea to replace them. Also you probably will need a new gasket as when taking old one off (it is glued) it may rip apart.
For e-series - you will need a new HEPA filter.
(parts HERE)
For Parts see
Mar 03, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Nilfisk GD930 vacuum-can't find replacement brush
Hello mddamus,
Try this link to a Nilfisk supplier, speak with a rep and they should be able to identify exactly what you need and provide that part for you.. http://www.nilfiskcfm.com/ProductAcc.aspx?m=15
Regards,
Rick
Dec 06, 2008 | Nilfisk GD 930 Canister Vacuum
I have a shop vac, and id like to use it to **** up water. do i need special parts or what exactly do i have to do to use it for that purpose?
the machine should have a filter inside if it looks like a big foam sleeve than your ready to go, if it takes a paper bag as well or a paper sleeve over the big foam sleeve you want to remove them ( not the foam ) because the paper would fall apart and make a big mess in the machine.
Sep 21, 2008 | Shop Vac Vacuums
Upper Filter gets clogged quickly
You may have to replace the filters, air maybe restricted going thru them. The main filter is part #73494, and the foam #74038. Also make sure the SLINGER/CYCLONE ASSY part #74068 isn't clogged up.
Jun 10, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
